Community Member
how to change "Your current options" to become our custom label
Dear All,
how to change "Your current options" in the IP Phone display, to become our custom label?
Jerri
is it CUCM or CME?
unfortunately its not possible to change that message in linux based CUCM but in CME
telephony-service
system message "Custom Label"
Please rate all the useful posts
//Suresh Please rate all the useful posts.
Hi jerry,
I don't know if it works out or not but if you want to try then refer below steps
1). download SCCP-dictionary.utf-8.xml from CUCM (tftp -i GET SCCP-dictionary.utf-8.xml)
2). Edit that file which contains "Your current options" as per your requirement and save it.
3). Upload file to all tftp servers (if you have multiple).
4). Restart tftp service of all tftp servers (if you have multiple).
If restarting tftp service don't help you then try to do factory reset of the phone.
Nishant Savalia
Regards, Nishant Savalia
949
