How to change speed dial names on a 7914???
henleybeachsa
I have a Cisco IP 7961 with a 7914 Expansion Module and I need to change the staff speed dial names. I've printed off the manual but I can't figure it out?
Chintan Gajjar
Level 8
Level 8
is it on CUCM ?
regards
Chintan
Pedro Francezi
Please check out the following link if you are using a CUCM
https://supportforums.cisco.com/document/12098351/configuring-speed-dial-and-abbreviated-dial-setup-cucm
Guru Mysoruu
HI,
Are you trying to change the speed dial in CUM or in Phone.
If you are are trying to change in Phone,then manually change in the phone.
If you are trying to change in CUCM follow the link provided by Pedro
Gurudath K S
