how to change the bypass reception code
I would like to know where I need to go to stop outside callers from bypassing reception.  Can I change the code or just turn it off so noone can bypass reception.
Using Cisco BE6k Cisco Unity Connection version: 9.1.2.10000-10
Mike
  • IP Telephony
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
OK, use time of day routing
OK, use time of day routing feature of CUCM and configure it something like this:
time period - define your hours of operation
time scheudle - define the days
partition - NormalHours, apply the above time schedule
Add the above partition to CSS applied to the voice gateway/trunk, make sure the partition is listed above your default partition asigned to this DN
Build translation pattern in the NormalHours partition, translate the call to the receoptionist extension
Build CTI Route point (may have this already) in normal partition and send the call to voicemail call handler.
This way when call arrives during business hours it will be transferred to the operator and after hours will go to unity auto attendant.
Chris
Please elaborate what you
Please elaborate what you mean on bypassing reception, what is the call flow, how would you like it and what is happening?
Chris
Someone from outside calls
Someone from outside calls your company and as soon as it rings, they hit certain keys and enter your ext.  This brings the call right to your desk phone without going through the operator.  Is there a way to change or remove the default code to stop them from doing this.  For after hours, it would be nice to define our own code for internal use only?
So, should the caller hear a
So, should the caller hear a company welcome message (played by UCXN call handler) and them be transferred to an operator? You simply adjust the call handler not to allow caller input and ignore the key presses to acheive this.
Chris
The caller should go directly
The caller should go directly to the receptionist, not allowed to go direct to the extension during business hours.  After hours, they would get the auto attendant and then they could dial by extension.  I have already removed the ext.  I don't want external callers to have access to after hours.
Chris
66
