How to change the time ??
IngGerardo013
Hello guys,
I would like to know how to change the time in a 7970G cisco phone, I dont know if the phone gets the date from a server, but checking  typing this command: show clock in the CME UC520, date and time shows correct , I powered off / powered on the phone and it remains with the same Wrong time (just time no date), any adivce would be very well received. Thanks!
Patrick Born
Hi IngGeraldo013,
You've posted your question in the small business phone section where people help each other with the SPA5xx IP phone family.
I don't believe there's much 7970 expertise here. Please consider posting to another section such as this one: https://supportforums.cisco.com/community/netpro/collaboration-voice-video/ip-telephony
Good luck,
Patrick
Hi Gerardo,
I have moved this discussion over to the IP Telephony area for you.
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
Justin Brenton
Level 4
Level 4
Hi Gerardo,
Complete these steps on the Cisco CallManager Express in order to display the correct time:
  1. Configure the type 7970 command under the ephone.
    ephone  1
     device-security-mode none
     mac-address 0017.59E7.492C
     type 7970
     button  1:1
  2. Configure the time-zone command under the Telephony service.
    telephony-service
     max-ephones 5
     max-dn 5
     ip source-address 10.1.0.1 port 2000
     auto assign 1 to 5
     time-zone 8
     dialplan-pattern 1 ... extension-length 4 extension-pattern 9000
     voicemail 6000
     max-conferences 12 gain -6
     transfer-system full-consult
     create cnf-files version-stamp 7960 Feb 05 2009 12:44:03
  3. Configure the create cnf-files command under the Telephony service in order to implement the change in step 1 and 2.
    CME-CUE(config-telephony)#create cnf-files
    CNF file creation is already On
    Updating CNF files
    CNF files update complete
Verify
Comlete these steps in order to reset the Cisco 7970 IP Phone:
  1. Press the Settings button on the Cisco 7970 IP Phone.
  2. Enter the **#** key sequence on the phone keypad in order to reset the phone.
    The correct time displays on the Cisco 7970 IP Phone after the reset.
Troubleshoot
Complete these steps if the time displayed on the Cisco 7970 IP Phone is incorrect:
  • Verify the phone configuration on Cisco CallManager Express.
  • Display the 7970 configuration file on Cisco CallManager Express. The name of the file is xmldefault7970.cnf.xml, which is located in the system:/its/ directory. Complete these steps in order to display the configuration file:
    1. Log in to Cisco CallManager Express.
    2. Complete these steps in order to display the 7970 configuration file:
      1. Issue the cd system: command.
      2. Issue the cd its command.
      3. Issue the more xmldefault7970.cnf.xml command in order to dump the configuration.
    3. Verify that the time zone parameter is correctly configured . The output of the command is shown here:
      CME-CUE#more xmldefault7970.cnf.xml
      M/D/YA
      Greenwich Standard Time
      2000
      10.1.0.1
      {7970 Feb 05 2009 12:31:07}
      English_United_States
      en
      United_States
      United_States
      http://10.1.0.1:80/localdirectory
    4. Complete these steps in order to verify that Cisco CallManager   Express successfully sends the 7970 configuration file to the Cisco 7970   IP Phone:
      2. Issue the debug tftp events command.
      3. Issue the terminal monitor command.
      4. Reset the Cisco 7970 IP Phone.
        This output shows the results of the debug tftp events command. The bold text indicates the phone has successfully received its configuration file.
        Feb  5 12:38:21.539: TFTP: Opened system:/its/XMLDefault7970.cnf.xml, fd 0, size
         1033 for process 287
        Feb  5 12:38:21.543: TFTP: Finished system:/its/XMLDefault7970.cnf.xml, time 00:
        00:00 for process 287
        Feb  5 12:38:24.383: %IPPHONE-6-REG_ALARM: 20: Name=SEP001759E7492C Load= SCCP70
        .8-3-2S Last=Phone-Keypad
        Feb  5 12:38:24.427: %IPPHONE-6-REGISTER: ephone-1:SEP001759E7492C IP:10.1.0.4 S
        ocket:1 DeviceType:Phone has
                    registered.
Justin
