How to change the UI configuration
I am trying to modify the Auto call select and the Softkey timer on a 7970 phone. I cannot edit the parameter. Is there a way of doing it. I am using CCM 5.0.4 and SCCP11.8.2-1S
1 ACCEPTED SOLUTION
Bronze
Re: How to change the UI configuration
Bronze
Thanks, I tried with 5.1 and it is possible to change the UI configuration. I have created a config file for 5.0.4 and it works.
I was able to set the auto-call select to disable.
236
