How to check call logs
How can i check the call logs(calls made, to which number it was made etc.)
from the call manager(version 5.1). Please guide me how I can view the above from the call manager.
rgds
Rajesh
Re: How to check call logs
Rajesh,
You need to go to serviceability->control center and start the cdr services.
Then go to
https://callmanager:8443/car/Logon.jsp
logon with the default passwords
then run a report. User report ->bills->department and select the users you want to run. that will give you a list of who they called and when and for how long.
in CUCM there are no default passwords, you need to add a user to the CAR Admin group in order to log into CAR
It's not like previous versions in which the 1st logon was with admin/admin and then you added users.
In this and 6.x release you need to add users to the group PRIOR to login in.
java
if this helps, please rate
www.cisco.com/go/pdi
421
