How to Check CME license in CLI
I need to verify my CME phone and User license in my 2851 router is there any option to find it.(Used and Unused license)
Hari
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: How to Check CME license in CLI
Up to maximum, check:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_device_support_tables_list.html
Please remember to rate useful posts with the scrollbox below.
There is no license enforcement or installation in CME so there is nothing to verify.
So that means we can add as many phone as we want ....
Cisco Router is sold like below;
If CCME FL for 25 users is sold. How can   we veriyfing this situation;
http://www.cisco.com/web/partners/downloads/partner/WWChannels/technology/ipc/downloads/ucme_8_5_ue_8_5_ucc_og.pdf
Base router, 128 MB flash, 256 MB DRAM,
DSP-32, AIM2-CUE, CCME FL for 25
users, CUE FL for 25 users, 25 phone
device licenses, Cisco IOS Advanced IP
Services, 5 UCC desktop client licenses
Hall of Fame Super Red
Hi Mehmet,
In the licensing scheme, the cme-srst feature license is a "paper"
RTU (right to use) license only. There is nothing to load on the router
itself
Use the "show license" command to get started;
Activating CME-SRST Feature License
The ISR-G2 comes with a 60-day evaluation license. After 60 days, the license changes to “right to use”.
The customer is required to pay for the CME-SRST feature license which is valid for 12 years.
Prerequisites
• UCK9 license
• ISR-G2 already accepts UC CLIs
SUMMARY STEPS
1. show license detail cme-srst
2. configure terminal
3. license accept end user agreement
4. exit
5. show license detail cme-srst
6. write mem
DETAILED STEPS
Command or Action Purpose
Step 1 show license detail cme-srst
Example:
Router# show license detail cme-srst
Displays the available cme-srst license. EULA should be in NOT
ACCEPTED state.
Step 2 configure terminal
Example:
Router# configure terminal
Enters global configuration mode.
Step 3 license accept end user agreement
Example:
Router(config)# license accept end user
agreement
Configures a one-time acceptance of the EULA for cme-srst
license.
Accepts EULA by typing YES.
Step 4 exit
Example:
Router(config)# exit
Exits global configuration mode.
Step 5 show license detail cme-srst
Example:
ACCEPTED state.
Step 6 write mem
Example:
Router# write mem
Saves configuration.
Command or Action
This is explained in more detail starting on Page 15;
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.pdf
Cheers!
Rob
I see that someone has low-rated Rob's answer above that is, of course, 100% correct and complete. That is not fair.
To partially compensate, I have rated it again: +5.
OK
Thanks for you help.
Blue
As said earlier , CME-SRST licenses are paper license and will not be seen in the sh run or any out put of the router.
Customer has to keep in mind and remember what they have purchsed from Cisco.
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
6771
