How to check number of digits send by telco on MGCP gateway?
piotrderda
Hello group,
I am currently facing a slight problem - we recently aquired a company with IP Telephony infrastructure and working toward creating a consistent dial plan.
To complete this, I need to find out how many digits is forwarded by telco for incoming PSTN call for each location. I was able to easily discover this on H.323 gateway (debug voice dialplan), however stuck in doing the same on MGCP (debug voice ccapi does not provide me that info). Is any other way (maybe on the CUCM itself)?
Peter
JATINDER KUMAR
Which line you are using to dial the number outside..
if it is isdn then you can use "debug isdn q931" which gives everything related to dialed or recieved number. Hope this helps
