How to check remaining device RTU licenses in CM 4.1
Is there a way to check remaining device RightToUse (RTU) licenses in CM 4.1.3?
I'm familiar with the License Manager feature in CUCM 5.1.3 and any similar functionality in ver 4.1.
Thanks!
1 ACCEPTED SOLUTION
Re: How to check remaining device RTU licenses in CM 4.1
With CM 4.x you buy a license per phone type. If you have a 7825 it can officially support upto 1000 phones, 7835 - 2500 phones and so on...If you have 1000 phones (7940) then you should have bought from your Cisco Partner 1000 of the SW-CCM-UL-7940. So to answer your question, you can simply look at how many more devices u can expand to on ur current server based on how many devices you have right now.
1 REPLY
131
