How to check time on remote cisco IP phone 7942?
Cisco IP Phones 7911 and 7940 have correctly updated time-zone, but cisco type 7942 does not want to update timezone.
Blue
HI
Just give ip address of the phone in internet browser. It will open IP phones information window. It has following information
Time
15:17:34
Time Zone
Asia/Kolkata
Date
26/03/12
Ronak Patel
Please rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
I forgot to say, ip address of the phone in internet browser shows info only for 7911 and 7940, for 7942 does not show anything.
Blue
What is the CUCM and Firmware on that phone.
Ronak Patel
Cisco Unified Communications Manager Express
Version 7.1
load 7942 SCCP42.8-3-3S
What is the firmware version running on 7942 ? Update it to the latest if not already.
GP.
It is installed:
Version 7.1
What from bellow should I use for a new firmware:
1. apps42.9-2-3TH1-9.sbn
2. cnu42.9-2-3TH1-9.sbn
3. cvm42sccp.9-2-3TH1-9.sbn
4. dsp42.9-2-3TH1-9.sbn
5. jar42sccp.9-2-3TH1-9.sbn
6. SCCP42.9-2-3S.loads
7. term42.default.loads
8. term62.default.loads
Re: How to check time on remote cisco IP phone 7942?
It will be SCCP42.9-2-3S.loads but am not sure if direct upgrade will be possible looking at present & targetted versions. If it doesnt then an intermediate upgrade step will be needed. Referring the release notes for firmware version 9.2.3 should tell you if it needs one & what it is.
GP.
Blue
Is phone and CME router on same network or are seperate via some VPN.
Also please do no create cnf-files and create cnf-files and reset the phones
Ronak Patel
phone and cme are on the same network.
no create cnf-files, create cnf-files and phones reset did not help.
687
