04-28-2014 09:57 AM - edited 03-16-2019 10:36 PM
How to check which versions of IP Phone firmware were installed in cucm?
in DEVICE DEFAULT displays only current version
i need to downgrade to previosly installed versions, but i cant see wich versions were installed
Solved! Go to Solution.
04-28-2014 10:10 AM
In addition to what AOK[+5] has said, u can run the command from CLI to what all firmware are available in CUCM for IP phone models.
example for 3905 model.
file list tftp *3905*
regds,
aman
04-29-2014 01:41 AM
You are not going to get anything on the 794X/6X phones that way..Try this..
file list tftp SCCP42*
file list tftp SCCP45*
file list tftp SCCP75*
The problem with this is that it will show you all the files thta have been installed in the past for these phones. The device defaults page is the only place you will know the current firmware the phones are running
04-28-2014 10:07 AM
The device defaults is the current version on the phone unless there is a specific firmware on the IP phone itself. Its in the device defaults that the phones know which firmware to load..
04-28-2014 10:10 AM
regds,
aman
04-29-2014 01:14 AM
Thank you for reply
why it is not showing over ip phones?
admin:file list tftp *3905*
APP3905.9-2-1-0.zz APP3905.9-2-2-0.zz
CP3905.9-2-1-0.loads CP3905.9-2-2-0.loads
dir count = 0, file count = 4
admin:file list tftp *6921*
dir count = 0, file count = 0
admin:file list tftp *6945*
SCCP6945.9-2-1-0.bin1.sgn SCCP6945.9-2-1-0.bin2.sgn
SCCP6945.9-2-1-0.bin3.sgn SCCP6945.9-2-1-0.bin4.sgn
SCCP6945.9-2-1-0.loads SCCP6945.9-3-3-2-SR1.bin1.sgn
SCCP6945.9-3-3-2-SR1.bin2.sgn SCCP6945.9-3-3-2-SR1.bin3.sgn
SCCP6945.9-3-3-2-SR1.bin4.sgn SCCP6945.9-3-3-2-SR1.loads
SIP6945.9-1-1-0.bin1.sgn SIP6945.9-1-1-0.bin2.sgn
SIP6945.9-1-1-0.bin3.sgn SIP6945.9-1-1-0.bin4.sgn
SIP6945.9-1-1-0.loads SIP6945.9-3-3-2.bin1.sgn
SIP6945.9-3-3-2.bin2.sgn SIP6945.9-3-3-2.bin3.sgn
SIP6945.9-3-3-2.bin4.sgn SIP6945.9-3-3-2.loads
dir count = 0, file count = 20
admin:file list tftp *7945*
admin:file list tftp *7975*
04-29-2014 01:18 AM
Hi ,
can u share the snapshot where it shows nothing?
regds,
aman
04-29-2014 01:40 AM
You can also try:
file list activelog installed_options.
That should show you all added firmware.
Carlo
04-29-2014 06:13 AM
ok tomorrow i will check and reply
04-29-2014 01:41 AM
04-29-2014 02:05 AM
there are many ways of searching
you can try what AOK has suggested. Also, u can use file list tftp SCCP* , file list tftp SIP* , file list tftp *79*
regds,
aman
04-30-2014 02:07 AM
file list tftp *45SCCP* worked
