How to check which versions of IP Phone firmware were installed in cucm?
in DEVICE DEFAULT displays only current version
i need to downgrade to previosly installed versions, but i cant see wich versions were installed
2 ACCEPTED SOLUTIONS
VIP Purple
Hi,  In addition to what AOK[
In addition to what AOK[+5] has said, u can run the command from CLI to what all firmware are available in CUCM  for IP phone models.
example for 3905 model.
file list tftp *3905*
regds,
aman
VIP Super Bronze
You are not going to get
You are not going to get anything on the 794X/6X phones that way..Try this..
file list tftp SCCP42*
file list tftp SCCP45*
file list tftp SCCP75*
The problem with this is that it will show you all the files thta have been installed in the past for these phones. The device defaults page is the only place you will know the current firmware the phones are running
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
The device defaults is the
The device defaults is the current version on the phone unless there is a specific firmware on the IP phone itself. Its in the device defaults that the phones know which firmware to load..
VIP Purple
regds,
aman
Thank you for replywhy it is
Thank you for reply
why it is not showing over ip phones?
admin:file list tftp *3905*
APP3905.9-2-1-0.zz                      APP3905.9-2-2-0.zz
CP3905.9-2-1-0.loads                    CP3905.9-2-2-0.loads
dir count = 0, file count = 4
admin:file list tftp *6921*
dir count = 0, file count = 0
admin:file list tftp *6945*
SCCP6945.9-2-1-0.bin1.sgn               SCCP6945.9-2-1-0.bin2.sgn
SCCP6945.9-2-1-0.bin3.sgn               SCCP6945.9-2-1-0.bin4.sgn
SCCP6945.9-2-1-0.loads                  SCCP6945.9-3-3-2-SR1.bin1.sgn
SCCP6945.9-3-3-2-SR1.bin2.sgn           SCCP6945.9-3-3-2-SR1.bin3.sgn
SCCP6945.9-3-3-2-SR1.bin4.sgn           SCCP6945.9-3-3-2-SR1.loads
SIP6945.9-1-1-0.bin1.sgn                SIP6945.9-1-1-0.bin2.sgn
SIP6945.9-1-1-0.bin3.sgn                SIP6945.9-1-1-0.bin4.sgn
SIP6945.9-1-1-0.loads                   SIP6945.9-3-3-2.bin1.sgn
SIP6945.9-3-3-2.bin2.sgn                SIP6945.9-3-3-2.bin3.sgn
SIP6945.9-3-3-2.bin4.sgn                SIP6945.9-3-3-2.loads
dir count = 0, file count = 20
admin:file list tftp *7945*
admin:file list tftp *7975*
VIP Purple
Hi , can u share the snapshot
Hi ,
can u share the snapshot where it shows nothing?
regds,
aman
You can also try:file list
You can also try:
file list activelog installed_options.
That should show you all added firmware.
Carlo
Please rate all helpful posts "The more you help the more you learn"
ok tomorrow i will check and
ok tomorrow i will check and reply
VIP Super Bronze
VIP Purple
Hi, there are many ways of
there are many ways of searching
you can try what AOK has suggested. Also, u can use  file list tftp SCCP* , file list tftp SIP* , file list tftp *79*
regds,
aman
file list tftp *45SCCP*
file list tftp *45SCCP* worked
4138
