How to clear CUCMBE 5000 Hardware server beeping?
On my CUCMBE 5000 Server I notice that there was a hard drive failure and the system start to emit sounds (beeping). Recently we acquire a hard drive from Cisco (the same model) and replace the failed hard drive, however the system is still beeping. Is there anything to do so that the system resumes a normal operation?
1 REPLY
beeping problem is always an hardware failure, incorrect hardware plug to the server or most likely memory issue. try fixing all of the above solution.
209
