how to clear the hung calls in CUBE?
I'm installing a new CUBE as SIP-SIP gateway in Cisco 2921, IOS: 15.1(4)M3. When i tried few test calls, I saw couple of hung calls in it.
I tried clearing them manually with the below command but it didn't help.
clear call voice causecode identifier{id identifier | media-inactive | calling-number number | called-number number}
>> https://supportforums.cisco.com/docs/DOC-34379
The call legs are still in connecting status.
2    : 2152 13:36:28.319 CET Tue Feb 11 2014.1 +-1 pid:200 Answer 222022029 connecting
dur 00:00:00 tx:0/0 rx:0/0
IP X.X.X.97:24578 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long duration call duration:n/a timestamp:n/a
2    : 2157 13:38:54.589 CET Tue Feb 11 2014.1 +-1 pid:200 Answer 222022029 connecting
IP X.X.X.97:24582 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
Also, I tried enabling media inactivity timer but it would clear only the calls in 'Connected' status If I understand correctly.
how to clear those hung calls? and what could be the cause of it?
Any help would be much appreciated.
Thanks in advance
Suresh
//Suresh Please rate all the useful posts.
Re:how to clear the hung calls in CUBE?
Hi Suresh,
Step no 6 in the following link:
The Media Inactivity Timer enables the Active/Standby router pair to monitor and disconnect calls if no Real-Time Protocol (RTP) packets are received within a configurable time period.
When RTP packets for a call are not received by the Active/Standby router, the SIP Media Inactivity Timer releases the session. This is used to guard against any hung sessions that might have resulted from the failover in the event that a normal call disconnect does not clear the call.
The same duration for the Media Inactivity Timer should be configured on both routers. The default value is 28 seconds. This timer is configured as follows:
ip rtcp report interval 3000 gateway media-inactivity-criteria all timer receive-rtp 86400 timer receive-rtcp 5
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/112095-cube-hsrp-config-00.html#step6
Kindly rate the post accordingly.
Sent from Cisco Technical Support Android App
Hi Kevin,
Yes I did try that feature but no luck, the calls are not yet cleared. but I enabled that feature after I saw the call hanging. and when I executed 'show call active voice brief' I still see 'media inactivity detected=No'.
VIP Super Bronze
Suresh have you tried this:
ip rtcp report interval 5000
gateway
timer media-inactive 5
The challenge you may face is that the media inactivity was not configured before this call started, hence it cant activate the time for this particular call...
Give it a go, lets know if it works. Even if it doesnt I suggest you enable this on your CUBE going forward, so you dont haver hung calls in the future
example: You can use the debug ccsip events to see the media inactivity timer kicking in for a call...
Router# debug ccsip events
00:04:29: sipSPICreateAndStartRtpTimer: Valid RTP/RTCP session found and CLI ena
bled to create and start the inactivity timer
00:04:29: sipSPICreateAndStartRtpTimer:Media Inactivity timer created for call.
Mfactor(from CLI): 5 RTCP bandwidth: 500
RTCP Interval(in ms): 5000
Normalized RTCP interval (in ms):25000
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hello Deji,
As I enabled the inactivity timer after the calls, it seems they are not detecting and clearing those hung calls.
I tried the below
      ip rtcp report interval 9000
      gateway
      media-inactivity-criteria rtcp
Also, I'm just wondering what could be the cause for these sessions hanging? could it be the IOS or configurations or Provider side? any idea?
VIP Super Bronze
I have seen them on our CUBE(s) too and I honestly dont know why. It may be IOS related. This is why its good prractice to have media inactivity configured. Its not something to worry about though.
one of my friends from tac said, only reboot would clear those calls. did the reboot and the hung calls were cleared.
thanks everyone for your suggestions.
Suresh,
The basic thing would be resseting the TRUNK or the  "clear call voice causecode 17 called-number 2126315001"
. This to be honest looks like a IOS based issue.
Could you let us know whats the ios your running?
Kevin
Kevin, it's Cisco 2921, IOS: 15.1(4)M3
1229
