How to configure BRI in CCME point to multipoint
I've a CCME with 2 bri, ISDN line is point to multipoint, what is command for solved my problem ?
Thanks all
Dario
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: How to configure BRI in CCME point to multipoint
12.4(4)XJ4 is rock stable, but not very recent.
Else take a pick from recent 12.4 T
That is the default configuration and no command is needed.
Only, recommend you use "isdn tei-negotiation preserve".
I've use "isdn tei-negotiation preserve" but this is isdn error when try to call.
003230: *Jun 18 12:55:47.731 Berlin: ISDN BR0/0/0 SERROR: L2_Go: at bailout DLCB is NULL
L2: sapi 0 tei 127 ces 0 ev 0x250
003231: *Jun 18 12:55:51.727 Berlin: ISDN BR0/0/0 SERROR: L2_Go: at bailout DLCB is NULL
003232: *Jun 18 12:55:51.727 Berlin: ISDN BR0/0/0 **ERROR**: CCBRI_Go: NO CCB Src->L3 call id 0x8016, event 0x95 ces 0
003233: *Jun 18 12:55:51.727 Berlin: ISDN **ERROR**: Module-CCBRI Function-_Go Error-Event received for an unrecognized call. Data- 95, 0
Likely buggy IOS, upgrade to something else.
Thanks,what IOS do you recommend?
Now I have install c2801-advipservicesk9-mz.124-19.bin when try to call error is :
"000365: .Jun 24 14:06:53.899: ISDN BR0/0/0 **ERROR**: CC_CHAN_GetIdleChanbri: All channels busy"
Try what I've indicated above that works for sure. Then you will have time to upgrade.
Now IOS is 12,4 (4) XJ4 but not call in or out.
Debug Isdn Error:
001801: *Jul 7 17:35:24.971: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
L2: sapi 63 tei 127 ces 0 ev 0x650
001802: *Jul 7 17:35:25.007: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
L2: sapi 63 tei 127 ces 0 ev 0x3
001803: *Jul 7 17:35:26.971: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
001804: *Jul 7 17:35:27.011: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
Have you an idea ?
bad, does the line work with an ISDN telephone ?
yes work fine, probably i've bad configuration ?
Post it here.
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
service sequence-numbers
hostname CCME
boot-start-marker
boot system flash c2801-spservicesk9-mz.124-11.XJ4.bin
boot-end-marker
no logging buffered
enable secret 5 $1$h43y$TxrNu.aYqXMARAaO9Ue1q/
no aaa new-model
clock timezone Berlin 1
clock summer-time Berlin date Mar 30 2003 2:00 Oct 26 2003 3:00
network-clock-participate wic 0
network-clock-participate wic 1
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.1.1 10.0.1.79
ip dhcp excluded-address 10.0.1.86 10.0.1.254
ip dhcp pool Pool
import all
network 10.0.1.0 255.255.255.0
dns-server 10.0.1.9 10.0.1.19
option 150 ip 10.0.1.4
ip telnet source-interface FastEthernet0/0
no ip ftp passive
ip name-server 10.0.1.9
ip name-server 10.0.1.19
ip ssh time-out 60
ip ssh authentication-retries 2
isdn switch-type basic-net3
voice-card 0
voice translation-rule 1
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1
username admin password 7 08374342080B00
ip address 10.0.1.4 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface BRI0/0/0
description Voce
no ip address
isdn incoming-voice voice
interface BRI0/0/1
no ip address
isdn point-to-point-setup
interface BRI0/1/0
description GSM
no ip address
interface BRI0/1/1
no ip address
ip route 0.0.0.0 0.0.0.0 10.0.1.253
ip http server
ip http secure-server
control-plane
voice-port 0/0/0
compand-type a-law
description Voce
voice-port 0/0/1
voice-port 0/1/0
compand-type a-law
description GSM
voice-port 0/1/1
dial-peer cor custom
dial-peer voice 1 pots
description Dial Plan
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
destination-pattern 0T
port 0/0/0
prefix 0
dial-peer voice 2 pots
destination-pattern 3T
port 0/1/0
prefix 3
telephony-service
max-ephones 25
max-dn 25
ip source-address 10.0.1.4 port 2000
time-zone 23
time-format 24
date-format dd-mm-yy
max-conferences 4 gain -6
web admin system name admin secret 5 $1$CP/9$Cvy85UASAsPl6CpjIwNNI1
transfer-system full-consult
create cnf-files version-stamp 7960 Jun 24 2009 14:34:43
ephone-dn 1 dual-line
number 930
label Dario
name Dario Pirovano
ephone 1
username "dpirovano"
mac-address 0023.331A.6644
type 7960
button 1f1
line con 0
line aux 0
line vty 0 4
privilege level 15
password 7 07192E404F1B1C
login local
transport input telnet ssh
scheduler allocate 20000 1000
ntp update-calendar
ntp server 10.0.1.9 source FastEthernet0/0 prefer
ntp server 172.22.1.107 source FastEthernet0/0
end
Config is correct. You only would need
network-clock-select 1 bri 0/0/0
but that probably will not change anything.
I don't know what to think, sorry.
1564
