how to configure Cisco unity Express 7.0.5 for cisco unified communications manager 7.1 (3b)
My question is regarding Compatibility with  cisco unified  communications manager 7.1 (3b) and Cisco unity Express 7.0.5.
If is  yes , can I have an exemple of configuration?
I find this step of  configuration but not my scenario .
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a0080289ef0.shtml#cm5andlater
http://www.cisco.com/application/pdf/en/us/guest/products/ps5520/c1059/ccmigration_09186a00802d95e6.pdf
Thanks  !
Re: how to configure Cisco unity Express 7.0.5 for cisco unifie
Table 2: Cisco  Unity Express: Unified CM Versions
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm
And the 1st link you posted is exactly what you need to do to integrate the systems, not sure why you say it's not your scenario.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hello ,
I try the solution but it's not work.
Cisco unified commucations manager 7.1.3  ip address 192.168.2.250
Gateway : ip address 192.168.2.254
Cisco Unity Express 7.0.5 ip address 192.168.2.253
The Voice pilot number is 200 when I dial the number is busy
Thanks !!
sh running-config
se-192-168-2-253# sh run
Generating configuration:
clock timezone America/Kentucky/Monticello
hostname se-192-168-2-253
ip domain-name sunutech.sn
line console
  exit
system language preferred "fr_FR"
software download server url "ftp://127.0.0.1/ftp" credentials hidden "6u/dKTN/h
sEuSAEfw40XlF2eFHnZfyUTSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfG
WTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
log trace local enable
privilege manage-users create
privilege ViewHistoricalReports create
privilege manage-passwords create
privilege broadcast create
privilege ManagePrompts create
privilege ViewPrivateList create
privilege ManagePublicList create
privilege local-broadcast create
privilege vm-imap create
privilege ViewRealTimeReports create
groupname Broadcasters create
username amiral create
username adminsuntech create
privilege manage-users description "Privilege to create, modify, and delete user
s and groups"
privilege ViewHistoricalReports description "Privilege to view historical report
s"
privilege manage-passwords description "Privilege to reset user passwords"
privilege broadcast description "Privilege to send local or remote broadcast mes
sages"
privilege ManagePrompts description "Privilege to create, modify, or delete syst
em prompts"
privilege ViewPrivateList description "Privilege to view private list"
privilege ManagePublicList description "Privilege to manage public lists"
privilege local-broadcast description "Privilege to send local broadcast message
s"
privilege vm-imap description "Privilege to manage personal voicemail via IMAP c
lient"
privilege ViewRealTimeReports description "Privilege to view realtime reports"
privilege manage-users operation user.configuration
privilege manage-users operation user.notification
privilege manage-users operation group.configuration
privilege manage-users operation user.password
privilege manage-users operation user.mailbox
privilege manage-users operation user.pin
privilege manage-users operation system.debug
privilege manage-users operation user.remote
privilege ViewHistoricalReports operation report.historical.view
privilege manage-passwords operation user.password
privilege manage-passwords operation user.pin
privilege manage-passwords operation system.debug
privilege broadcast operation broadcast.remote
privilege broadcast operation broadcast.local
privilege broadcast operation system.debug
privilege ManagePrompts operation prompt.modify
privilege ManagePrompts operation system.debug
privilege ViewPrivateList operation voicemail.lists.private.view
privilege ManagePublicList operation voicemail.lists.public
privilege ManagePublicList operation system.debug
privilege local-broadcast operation broadcast.local
privilege local-broadcast operation system.debug
privilege vm-imap operation voicemail.imap.user
privilege ViewRealTimeReports operation report.realtime
groupname Administrators member admincdc
groupname Broadcasters privilege broadcast
username amiral phonenumber "140"
restriction msg-notification create
restriction msg-notification min-digits 1
restriction msg-notification max-digits 30
restriction msg-notification dial-string preference 1 pattern * allowed
backup server url "ftp://127.0.0.1/ftp" credentials hidden "EWlTygcMhYmjazXhE/VN
XHCkplVV4KjescbDaLa4fl4WLSPFvv1rWUnfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8Z
calendar biz-schedule systemschedule
open day 1 from 00:00 to 24:00
open day 2 from 00:00 to 24:00
open day 3 from 00:00 to 24:00
open day 4 from 00:00 to 24:00
open day 5 from 00:00 to 24:00
open day 6 from 00:00 to 24:00
open day 7 from 00:00 to 24:00
end schedule
ccn application autoattendant aa
description "autoattendant"
enabled
maxsessions 8
script "aa.aef"
parameter "busClosedPrompt" "AABusinessClosed.wav"
parameter "holidayPrompt" "AAHolidayPrompt.wav"
parameter "welcomePrompt" "AAWelcome.wav"
parameter "disconnectAfterMenu" "false"
parameter "dialByFirstName" "false"
parameter "allowExternalTransfers" "false"
parameter "MaxRetry" "3"
parameter "dialByExtnAnytime" "false"
parameter "busOpenPrompt" "AABusinessOpen.wav"
parameter "businessSchedule" "systemschedule"
parameter "dialByExtnAnytimeInputLength" "4"
parameter "operExtn" "0"
end application
ccn application ciscomwiapplication aa
description "ciscomwiapplication"
enabled
maxsessions 6
script "setmwi.aef"
parameter "CallControlGroupID" "0"
parameter "strMWI_OFF_DN" "291"
parameter "strMWI_ON_DN" "292"
end application
ccn application msgnotification aa
description "msgnotification"
enabled
maxsessions 8
script "msgnotify.aef"
parameter "logoutUri" "http://localhost/voicemail/vxmlscripts/mbxLogout.jsp"
parameter "DelayBeforeSendDTMF" "1"
end application
ccn application promptmgmt aa
description "promptmgmt"
enabled
maxsessions 1
script "promptmgmt.aef"
end application
ccn application voicemail aa
description "voicemail"
enabled
maxsessions 8
script "voicebrowser.aef"
parameter "uri" "http://localhost/voicemail/vxmlscripts/login.vxml"
end application
ccn engine
end engine
ccn reporting historical
database local
description "se-192-168-2-253"
end reporting
ccn subsystem sip
gateway address "192.168.2.250"
end subsystem
ccn subsystem sip
mwi sip sub-notify
end subsystem
ccn trigger http urlname msgnotifytrg
application "msgnotification"
enabled
maxsessions 2
end trigger
ccn trigger http urlname mwiapp
application "ciscomwiapplication"
enabled
maxsessions 4
end trigger
ccn trigger sip phonenumber 200
application "voicemail"
enabled
locale "fr_FR"
maxsessions 4
end trigger
ccn trigger sip phonenumber 203
application "promptmgmt"
enabled
locale "fr_FR"
maxsessions 4
end trigger
ccn trigger sip phonenumber 204
application "autoattendant"
enabled
locale "fr_FR"
maxsessions 4
end trigger
service imap
enable
end imap
service voiceview
enable
end voiceview
voicemail default language fr_FR
voicemail broadcast recording time 300
voicemail default messagesize 240
voicemail notification restriction msg-notification
end
The gateway address under ccn subsystem sip shouldn't be 192.168.2.250. Should be the IP address of the router that hosts CUE. Verify your configuration against this guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_0/install/nuinstall.html#wp1109705
Hope it helps, please rate if it does.
Kind regards,
- Adrian.
738
