how to configure conference station 7936
tiger_401
Dear All,
I am using CME 4.2. I want to configure conference station 7936. Any pdf or sample configuration will be be very helpful.
Malik.
Hi Malik,
Are you using the "copy" command as shown in the example below;
The reason for this error message is that the archive command is for the .tar files and cannot be used with .bin files. In order to upgrade using the .bin file, use the copy command.
Router# copy tftp://x.x.x.x/P00307020300.sbn flash:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeinstl.html#wp998282
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeinstl.html#wp1070512
Hope this helps!
Rob
8 Replies 8
hi MK,
Can you tell me how it will register with my CME Router...because its showing configuring IP on the screen of the conference station...
Awaiting your reply,
Malik...
Hi Malik, what CCME version do you have, to register a the conference station:
1. Are you using vlans and DHCP or static IP configuration?
2. Make sure that you have the firmware file on your router flash.
CME(config)#tftp-server flash:filename
3.Associate yout phone with a firmware unter telephony-service config.
- load 7936 firmware-file
4. Create an ephone-dn TAG with a number
5. Create an ephone with the MAC ephone and assiciate the button with the number
ephone 10
mac XXXX.XXXX.XXXX
button 1:DN-TAG
6. Configure your phone 7936 eith the correct IP parameters and it shoukd register with out problems
Hope this help
David
Hi David,
Please have a look at attached configuration of my CME 4.2...Please advice how i can configure my 7936..
Hi, make sure that the firmware file is in yout router flash.
cmterm_7936.3-3-5-0.bin
Allow tftp function for this file:
tftp-server flash:cmterm_7936.3-3-5-0.bin
Under telephony sevices:
load 7936 cmterm_7936.3-3-5-0 (without extension)
Create the ephone-dn and ephone
ephone-dn 100 dual-line
description PHONE-7936
number XXXX
ephone 88
mac-address XXXX.XXXX.XXXX
button 1:100
type 7936
Hope this help
David
Dear David,
Thanks for your reply. One of the best and accurate reply ever seen in NetPro disccusion forms.
Dear David while uploading the firmware file in my router flash it gives this error:
%Tar checksum error in tftp://192.168.0.73/cmterm_7936.3-3-5-0.bin
Can you please help me resolving this issue. I will be very thankful to you.
Thanks & Regards,
Malik.
Hi Malik,
Hope this helps!
Rob
Thanks Rob,
u rock...copy command works...thanks for the reply...
Malik.
