Silver
How to configure CUBE
How would you configure CUBE when you only want simple outbound calls using callmanager 7.
I have downloaded some documentation from Cisco but this is already to complicated.
What I want is:
CM7---CUBE---SIPProvider.
On the CM I configure a SIP trunk pointing to the CUBE. What is needed on the CUBE to make a simple IP-to-IP configuration?
SIP provider wants username and password.
Also the CUBE is behind a Firewall, does this work? what is extra needed on the CUBE?
JH
1 REPLY
Re: How to configure CUBE
Hi Josh,
Take a look at CSCsu57129, which might be what you are running into.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsu57129
Michael.
639
