How to configure HTC mobile to integrate with CUCM 7.x
How can I configure HTC mobile to integrate with CUCM? and also the required configuration on CUCM?
Thanks a lot.
Re: How to configure HTC mobile to integrate with CUCM 7.x
I believe that Cisco may release an Android version of Cisco Mobile which is currently available for the iPhone.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps7290/ps7271/data_sheet_c78-595424.html
No idea of timescales, phone models, OS versions though.
First of all thank u, but i need information about HTC
As with any other device for which we do not have a SIP/SCCP client all you can try is downloading a SIP client on your phone and registering it as a 3rd party SIP endpoint.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
We have successfully register my G1 with SIP client -  csipsimple. You can find it in the Market. Works great via WiFi and HSDPA.
You need to configure it like a regular SIP softphone on CCM side. On csipsimple side when you add an account, put the user from CCM like a account name.If you used before nokia sip client with CCM 7.x the rest settings are the same
Best Regards,
Petko
Sorry I assumed that you meant an HTC phone running the Android operating system such as the HTC Desire, Legend, Wildfire etc.
HTC also make Windows phones - it would help if you state the model of phone and what operating system and version it is running.
You'll need a 3rd-party SIP client downloaded to your phone.  From there, the configuration steps are documented here (regardless of platform):
http://www.netcraftsmen.net/component/content/article/70-unified-communications/768-sip-endpoints-in-cisco-cucm-acrobits-softphone-and-weephone-for-iphone.html
Hailey
Please rate helpful posts!
1165
