How to configure individual Auth Code in CME
I have a CME version 8.6.
I need to configure individual FAC code for users .
Please share me the configuration details regarding FAC in CME.
Please revert.
Ankita Vig
Everyone's tags (3)
All that is contained in the CME admin guide which is available on CCO and the first place to look at for any CME config you need.
Configuring Forced Authorization
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmefac.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
The configuration mentioned in link provided is used for group fac , can the same be used for individual fac codes for users.
Ankita Vig
Hi, did you tested the config from CCO? I am trying to configure FAC on CCME but with password for individuals not for phones.
For example a Manager can make long distance call from any phone using his password.
you can use FAC per IP Phone
Use "after-hours override-code" in ephone-template not telephony-service, then apply the templates to the needed phones
But to do it for your manager,,
1. you can use extension mobility for him
2. or read these lines from the admin guide:
Logging in to a phone with a PIN only allows the user to override call blocking that is associated with
particular time periods. Blocking patterns that are in effect 7 days a week, 24 hours a day, and they
cannot be overridden by using a PIN
Haitham
712
