How to configure long distence calls in FXS device in ISR?
Hi, i have a ISR with interface FXS where i have a analog phone pluged. My call number do local calls but no long distance calls.
Hi @marcoscosta1,Do you have
Hi @marcoscosta1,
Do you have the proper dial-peer configured to do so?
How are your dial-peers configured? (Please, attach the output as a .txt file)
Rgrds,
Martin, IT Specialist
look my running config, you
look my running config, you could look my FXS setup.
Thanks...
I'm a little confused with
I'm a little confused with the international codes that apply to your country but you can try the following dial peer:
dial-peer voice <tag> pots
 destination-pattern 9T
 port <port>
Try this and let me know.
Rgrds,
34
