01-08-2012 04:37 AM - edited 03-16-2019 08:52 AM
There are 2 type of media resources
Software and Hardware.
How to add hardware media rescource on CUCM.
01-08-2012 08:50 AM
Refer the below link for configuring the Hardware media resources in CUCM and Router.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00807f8b30.shtml
Gnan.
01-09-2012 01:25 PM
sccp local Loopback100
sccp ccm 10.X.X.X identifier 2 version 7.0
sccp ccm 10.X.X.X identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 3 register abc_MTP
associate profile 2 register xyz_XCODE
associate profile 1 register mno_CONF
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 12
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
dspfarm profile 3 mtp
codec g711ulaw
maximum sessions software 10
Can you explain what type of this media resources are? Software or hardware
In CUCM, all above 3 are configre by ip address
01-09-2012 01:31 PM
XCODER and CFB on IOS ALWAYS use DSPs, so they're HW.
MTPs can be either SW or HW on IOS. Either they use DSPs or CPU/Memory from the ISR.
That MTP config already mentions what kind it is.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
01-09-2012 02:02 PM
I saw in cucm that mac address option while adding media resources. whats this???
Lets say if if any of the above media resources are not registered in call manager, then that site cant used these resources to use them. I means to say if site A media resources (CFB is not registered due to any case) then Site A users cannot make conferencing with Site B ?
01-09-2012 03:20 PM
I would strongly recommend you to fully review the SRND media resources chapter before anything else.
How MRG and MRGLs is explained there and that addresses your question.
Short answer: just as if a phone is not registered you cannot call it, if a media resource is not registered it's useless. That is addressed via MRGL/MRG but for that you need to review the SRND.
Whether to use MAC address or not depends on where the resources are, you can find the explanation by reviewing the CUCM help.
On the page where you saw the MAC address click help -> for this page.
java
