How to configure more then one SIP-ua authentication
I have a CME 7.1 on a Cisco 2811 router.
I'm trying to configure more than one SIP account. I have two or more numbers taken from the same SIP provider, but each one with different username and password.
what I have done until now is this:
voice service voip
allow-connections sip to sip
sip
registrar server
voice translation-rule 1
rule 1 /1003/ /0690282XXX/
rule 2 /1051/ /0690282YYY/
voice translation-rule 2
rule 1 /0690282XXX/ /1003/
rule 2 /0690282YYY/ /1051/
voice translation-profile In-Sip
translate called 2
voice translation-profile out-SipTrunk
translate calling 1
dial-peer voice 220 voip
translation-profile incoming In-Sip
translation-profile outgoing out-SipTrunk
destination-pattern [0,3]T
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
codec g711alaw
no vad
sip-ua
credentials username 0690282XXX password 7 XXX realm voip.eutelia.it
credentials username 0690282YYY password 7 YYY realm voip.eutelia.it
authentication username 0690282XXX password 7 XXX realm voip.eutelia.it
no remote-party-id
registrar dns:voip.eutelia.it expires 3600
sip-server dns:voip.eutelia.it
With the two "credentials" commands I was able to register the two numbers towards the SIP provider and it's possible to recieve the calls directed to 0690282XXX and 0690282YYY on the phones.
show sip-ua register status
Line peer expires(sec) registered P-Associated-URI
0690282YYY -1 1042 yes
0690282XXX -1 1015 yes
Instead calling from this number to outside it's impossible.
To resolve this I have added the command "authentication username 0690282XXX ..." but I was able to call outside using only the 0690282XXX.
Sip-ua can manage only one authentication string.
How can I make this work?
Re: How to configure more then one SIP-ua authentication
Unfortunately at this time we only support one authentication at a time. The only way for this to work is to have both SIP trunks have the same authentication.
I think this is something that we are working on, however.
hth,
nick
Well... I was not surprised, I expected a response of this kind.
But there is nothing that I can do to resolve the problem? Maybe a temporary solution while waiting the new release?
The workarounds require getting the providers involved - seeing if they will change your authentication or waive the registration requirement.
-nick
I've tried, it's impossible.
A SIP-Proxy can be a good thing to resolve my issue? If yes, do you know something easy to configure?
A SIP proxy should be able to take care of this, yes.
I do not know much on the Cisco Sip Proxy side of things, nor any 3rd party configurations.
I'm interested to know about your solution if you find one.
hth,
nick
You can use a voice port in the router and use authentication in the dial-peer pots like this:
dial-peer voice 111111 pots
answer-address 111111
destination-pattern 111111
forward-digits all
authentication username 111111@isp.com password 1234 realm isp.com
sip-ua
no remote-party-id
retry invite 3
retry notify 3
timers notify 100
registrar dns:isp.com:5060 expires 3600
sip-server dns:isp.com:5060
Let me know...
Did you ever get that to work so it showed different number pr configured credential ? I have the same problem after have configured 8 different credentials, only the number used with the authentication command is showed when calling out. I need the 8 different numbers to be showen.
What to do ?
Hi Steen Nielsen,
I resolved with the new CME 8.0 (and later) and Cisco IOS Release 15.0(1)XA (and later). With this new feature you can add multiple authentication strings in sip-ua.
What I have understood is that the command "credentials" works for calling in and the command "authentication" works for calling out.
Read this and try.
http://www.cisco.com/en/US/docs/ios/voice/sip/configuration/guide/sip_cg-multi-registrars.html#wp1070074
Best Regards,
Gianluigi Carella
17338
