11-28-2011 07:50 PM - edited 03-16-2019 08:16 AM
Hi all,
My customer has intention to add another E1 line to existing CME 8.6. How do I configure to have outbound calls on both lines? Please advise and assist.
Best regards,
Lawrence Chew
11-28-2011 08:27 PM
Since you currently have E1 then you should have a pots dial peer to send outbound calls over this E1
You can copy this config of the dial peer and change dial peer number and the port to the new E1 port in this case outbound calls will be load balanced over both E1 in a round robin
Or you can increase the preference in one of the dial peers using preference command to make it back one
But be aware in both cases you need to consider how the calling number will appear when calls being sent over the new E1 if there is different DID range !
Hope this help
If helpful rate
11-28-2011 08:48 PM
Thanks for the speedy reply. If calls over new E1, the DID will not reflec the correct number. How do i configure to have translation pattern on new E1, please advise and assist.
Best regards,
Lawrence Chew
11-28-2011 10:46 PM
If your getting the new e1 from the same telco then you can speak to them to have the same DID applied on the new isdn link
Then use same config on ur existing link and dial peers
But if the provider is different then you can not preserve the same DID in this case
Hope this help
If helpful rate
