How to configure SIP gateway with SP and CUCM 7
I would like to register a Cisco 2611 router as a SIP gateway with SP (Flowroute) to be able to make and receive calls from CUCM 7.
Could you point me to some guides/tutorials, I am a little bit puzzled, for example:
Do I need to create a two separate sip-ua, one to register with SP and one to register with CUCM?
How many dial-peers should I create for basic in and out calling?
Does different SP have different requirements on how to register with them?
I am new to VoIP and I am having trouble finding answers to those questions.
Any pointers would be much appreciated.
Blue
Hi Marcin,
Check if below link helps. It has most of the tested configuration.
http://www.cisco.com/en/US/solutions/ns340/ns414/ns728
/networking_solutions_products_genericcontent0900aecd805bd13d.html
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Re: How to configure SIP gateway with SP and CUCM 7
The link isn't working.
Hello Marcin,
is your 2611 an XM series router?
In order to achieve your goal you have to configure, in general,:
- @CUCM: a SIP Trunk to the 2611
- @2611: a) appropriate dial-peers to/from CUCM and to/from ITSP, b) registration to the ITSP. I have a sample configuration below
sip-ua
 credentials username xxx password xxx realm xxx
 authentication username xxx password xxx
 registrar dns:xxx expires 120
 sip-server dns:xxx
 host-registrar
# show sip-ua register status
Georgios
Please rate if you find this helpful.
593
