How to configure UC560?
Is it possible to have this kind  of configuration on UC560, for example specific range of extensions  (e.g. from 200 to 299) to make outgoing calls through specific FXO (e.g.  FXO 0/0 and FXO 0/1), whereas other range of extensions (e.g. from 300  to 399) to make outgoing calls through other  FXO-s (e.g. FXO 0/2 and   0/3)?
If yes, how can I do that with cisco configuration assistant?
Thank you.
Bj
1 ACCEPTED SOLUTION
Here
https://supportforums.cisco.com/docs/DOC-26186
This document explains what you need to do very well.
Is it possible ?
Yes
With Cisco Configuration Assistant ?
No
Using CLI you will need to customize all
dial-peer cor list
dial-peer voice pots
ephone-dn
voice-ports
Hi Mario,
Thank you for your reply.
It would be very helpfull if you colud give me an example of how to achive that.
Thank you
Brj
Here you go:
Mapping Outbound Calls to Unique FXS/FXO Ports on Analog Gateways
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtml
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Thanks Jorge,
I will see if that would solve my problem.
regards,
Brj
Here
Thank you very much Mario.
It is a very helpful document.
595
