How to Configure WAN codecs G.729
Hello Every One,
          I have got callmanager 4.1 running on windows 2000 in my head office. We recently opened a new Branch office which is connected directly from Head Office using the Point to Point Network . I just installed a layer 3 POE switch confgured data,voice Vlans and DHCP pools and started running ip telephony as  ( This is not SRST setup I dont have any gateways in the Brach office). I Would like to use G.729 codecs for my branch office telephone how is it possible.
Re: How to Configure WAN codecs G.729
Configure regions for HQ and branch, set G729 between them
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks for the great help.Please do understand that I am not familiar with the call manager as I completely work on AD and Exchange Server. It would be great if i can get some Screen shotted documentation or else a step by step guide.
This example should help.
http://www.cisco.rw/en/US/products/sw/voicesw/ps556/products_configuration_example09186a00803f8950.shtml
Hope to help, please rate if it does.
Best regards,
-- Adrián.
216
