how to control which sip account to use for outbound call
rlaudiano
hi, i have 3 sip accounts from the same provider and each of these accounts have their own caller-id. how can i control which sip account to use for outbound calls based on the destination number under CME 8.6?
UC520#sh run
Building configuration...
Current configuration : 33675 bytes
! Last configuration change at 23:31:10 PCTime Mon Sep 15 2014 by admin
! NVRAM config last updated at 23:33:26 PCTime Mon Sep 15 2014 by admin
version 15.1
parser config cache interface
no service pad
service internal
service compress-config
service sequence-numbers
hostname UC520
boot-start-marker
boot-end-marker
logging buffered 4096
enable secret 4 4LYLBj/m9tJslfvnut0KB75uPWP8/sM
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone PCTime 8 0
crypto pki trustpoint TP-self-signed-*****
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-*****
 revocation-check none
 rsakeypair TP-self-signed-*****
crypto pki certificate chain TP-self-signed-*****
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
        quit
dot11 syslog
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp pool phone
 import all
 network 10.1.1.0 255.255.255.0
 default-router 10.1.1.1
 option 150 ip 10.1.1.1
 dns-server 103.11.48.190 103.11.48.126
 domain-name 103.11.48.190
ip domain name sip.didlogic.net
ip name-server 103.11.48.190
ip name-server 103.11.48.126
ip inspect WAAS flush-timeout 10
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp supplementary-services
 port 0/0/3
  fallback-dn 205
trunk group ALL_FXO
 max-retry 5
 voice-class cause-code 1
 hunt-scheme sequential
voice call send-alert
voice rtp send-recv
voice service voip
 ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through
g711ulaw
 sip
  registrar server expires max 600 min 60
  localhost dns:sip.didlogic.net
  outbound-proxy dns:sip.sg.didlogic.net
  no update-callerid
voice class codec 1
 codec preference 1 g711ulaw
voice class custom-cptone CCAleavetone
 dualtone conference
  frequency 400 800
  cadence 400 50 200 50 200 50
voice class custom-cptone CCAjointone
 dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
voice class cause-code 1
 no-circuit
voice register global
 mode cme
 source-address 10.1.1.1 port 5060
 no outbound-proxy
 max-dn 56
 max-pool 14
 load 9971 sip9971.9-4-1-9
 authenticate register
 timezone 43
 date-format D/M/Y
 hold-alert
 voicemail 100
 url directory http://10.1.1.1/localdirectory
 tftp-path flash:
 create profile sync 0005017394511016
voice register dn  1
 translation-profile incoming SIP_Passthrough
 number 105
 call-forward b2bua busy 100
 call-forward b2bua noan 100 timeout 20
 call-forward b2bua unregistered 100
 name Living Room
 no-reg
 label Living Room
voice register dn  2
 number 102
 call-forward b2bua noan 100 timeout 10
 name Master Bedroom
 no-reg
 label Mommy
voice register dn  3
 number 103
 name Nana Bedroom
 no-reg
 label Christiana
voice register dn  4
 number 104
 name Dining Hall
 no-reg
 label Dining Hall
voice register pool  1
 id mac 08CC.6830.BF71
 session-transport tcp
 type 9971
 number 1 dn 1
 dtmf-relay rtp-nte
 username LivingRoom password cisco
 codec g711ulaw
 camera
 video
voice register pool  2
 id mac B4E9.B08C.A754
 type 9971
 number 1 dn 2
 dtmf-relay rtp-nte
 username Liezel password cisco
 codec g711ulaw
 camera
 video
voice register pool  3
 id mac 5017.FF96.7EE6
 type 9971
 number 1 dn 3
 dtmf-relay rtp-nte
 username christiana password cisco
 codec g711ulaw
 camera
 video
voice register pool  4
 id mac 5017.FF96.7A7B
 type 9971
 number 1 dn 4
 dtmf-relay rtp-nte
 username DiningHall password cisco
 codec g711ulaw
 camera
 video
voice hunt-group 1 parallel
 final 701
 list 205,104,105
 timeout 12
 pilot 700
voice hunt-group 2 parallel
 final 102
 list 102,103,104,105,205
 timeout 12
 pilot 701
voice source-group CCA_SIP_SOURCE_GROUP_CUE_CME
 access-list 2
 translation-profile incoming SIP_Incoming
voice source-group CCA_SIP_SOURCE_GROUP_EXTERNAL
 access-list 3
voice translation-rule 1
 rule 1 /\(^9\)/ //
voice translation-rule 2
 rule 1 /^9\(.*\)/ /65\1/
voice translation-rule 3
 rule 1 /^65......../ /965\2/
voice translation-rule 4
 rule 1 /1713******6/ /700/
voice translation-rule 5
 rule 1 /61********5/ /700/
voice translation-rule 6
 rule 1 /44*********2/ /700/
voice translation-rule 410
 rule 1 /^9\(.*\)/ /\1/
 rule 2 /^8\(.*\)/ /\1/
 rule 15 /^...$/ /65*******0/
voice translation-rule 411
 rule 1 /^9\(.*\)/ /ABCD9\1/
 rule 2 /^8\(.*\)/ /ABCD8\1/
voice translation-rule 412
 rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 422
 rule 15 /^ABCD\(.*\)/ /\1/
voice translation-rule 1000
 rule 1 /.*/ //
voice translation-rule 1111
 rule 15 /^.*$/ /65*******0/
voice translation-rule 1112
 rule 1 /^9/ //
 rule 2 /^8/ //
voice translation-rule 2222
voice translation-rule 3265
 rule 1 /\(^..............$\)/ /8\1/
 rule 2 /\(^.............$\)/ /8\1/
 rule 3 /\(^............$\)/ /8\1/
 rule 4 /\(^...........$\)/ /8\1/
 rule 5 /\(^..........$\)/ /8\1/
 rule 6 /\(^.........$\)/ /8\1/
 rule 7 /\(^........$\)/ /9\1/
 rule 8 /\(^.......$\)/ /9\1/
 rule 9 /\(^......$\)/ /9\1/
 rule 10 /\(^.....$\)/ /9\1/
 rule 11 /\(^....$\)/ /9\1/
 rule 15 /\(^ABCD$\)/ /ABCD\1/
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
 translate calling 1111
voice translation-profile CallBlocking
 translate called 2222
voice translation-profile DiscardDigit9
 translate called 1
voice translation-profile INCOMING_CallerID_PROFILE
 translate calling 3265
voice translation-profile Incoming_AU-BG_Called_5
 translate called 5
voice translation-profile Incoming_UK-BG_Called_6
 translate called 6
voice translation-profile Incoming_US-BG_Called_4
 translate called 4
voice translation-profile Local_SIP_Call_Add_65
 translate called 2
voice translation-profile OUTGOING_TRANSLATION_PROFILE
 translate called 1112
voice translation-profile PSTN_CallForwarding
 translate redirect-target 410
 translate redirect-called 410
voice translation-profile PSTN_Outgoing
voice translation-profile SIP_Incoming
 translate called 411
voice translation-profile SIP_Passthrough
 translate called 412
voice translation-profile SIP_Passthrough_CallBlocking
 translate called 422
voice translation-profile nondialable
 translate called 1000
voice-card 0
 dspfarm
 dsp services dspfarm
fax interface-type fax-mail
license udi pid UC520-8U-4FXO-K9 sn FTX1213Y07D
archive
 log config
  logging enable
  logging size 600
  hidekeys
username admin privilege 15 secret 4 4LYLBj/m9tsM
no ip ftp passive
ip tftp source-interface Loopback0
interface Loopback0
 ip address 10.1.10.2 255.255.255.252
 ip virtual-reassembly in
interface FastEthernet0/0
 ip address dhcp
 load-interval 30
 duplex full
 speed 100
interface Integrated-Service-Engine0/0
 description cue is initialized with default IMAP group
 ip unnumbered Loopback0
 service-module ip address 10.1.10.1 255.255.255.252
 service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
 switchport voice vlan 100
 no ip address
 macro description cisco-phone
 spanning-tree portfast
interface FastEthernet0/1/1
 no ip address
interface FastEthernet0/1/2
 no ip address
interface FastEthernet0/1/3
 no ip address
interface FastEthernet0/1/4
 no ip address
interface FastEthernet0/1/5
 no ip address
interface FastEthernet0/1/6
 no ip address
interface FastEthernet0/1/7
 no ip address
interface FastEthernet0/1/8
 switchport mode trunk
 no ip address
 macro description cisco-switch
interface Vlan1
 ip address 192.168.1.2 255.255.255.0
interface Vlan99
 ip address 192.168.99.2 255.255.255.0
interface Vlan100
 ip address 10.1.1.1 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
access-list 1 remark CCA_SIP_SOURCE_GROUP_ACL_INTERNAL
access-list 1 remark SDM_ACL Category=1
access-list 1 permit 192.168.1.2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 2 remark CCA_SIP_SOURCE_GROUP_ACL_INTERNAL
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 192.168.1.2
access-list 2 permit 192.168.1.0 0.0.0.255
access-list 2 permit 10.1.1.0 0.0.0.255
access-list 2 permit 10.1.10.0 0.0.0.3
access-list 3 permit 162.217.100.10
access-list 3 permit 192.170.159.194
access-list 3 permit 192.170.152.170
access-list 3 permit 95.154.254.93
access-list 3 remark CCA_SIP_SOURCE_GROUP_ACL_EXTERNAL
access-list 3 remark SDM_ACL Category=1
access-list 3 permit 101.0.103.146
access-list 3 permit 119.9.12.222
access-list 3 permit 176.74.184.153
access-list 3 permit 72.251.241.166
access-list 3 permit 207.198.125.133
access-list 3 deny   any
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 100 deny   ip 192.168.1.0 0.0.0.255 any
snmp-server community public RO
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias
tftp-server flash:/dkern9971.100609R2-9-4-1-9.sebn
tftp-server flash:/Desktops/CampusNight.png alias CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png alias TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png alias CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png alias TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png alias CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png alias TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png alias Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png alias TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png alias MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png alias TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png alias NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png alias TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml alias 320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml alias 320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml alias 320x216x16/List.xml
tftp-server flash:/phones/9971/sip9971.9-4-1-9.loads
tftp-server flash:/phones/9971/sboot9971.031610R1-9-4-1-9.sebn
tftp-server flash:/phones/9971/skern9971.022809R2-9-4-1-9.sebn
tftp-server flash:/phones/9971/rootfs9971.9-4-1-9.sebn
tftp-server flash:/phones/9971/kern9971.9-4-1-9.sebn
tftp-server flash:/phones/9971/dkern9971.100609R2-9-4-1-9.sebn
radius-server attribute 31 send nas-port-detail
control-plane
call threshold interface FastEthernet0/0 int-calls low 14 high 14
voice-port 0/0/0
 cptone SG
 station-id number 204
 caller-id enable
voice-port 0/0/1
 cptone SG
 station-id number 203
 caller-id enable
voice-port 0/0/2
 cptone SG
 station-id number 202
 caller-id enable
voice-port 0/0/3
 cptone SG
 timeouts ringing infinity
 description Panasonic Wireless Phone
 caller-id enable
voice-port 0/1/0
 trunk-group ALL_FXO 61
 translation-profile incoming INCOMING_CallerID_PROFILE
 cptone SG
 connection plar opx 700
 description Configured by CCA 4 FXO-0/1/0-Custom-BG
 caller-id enable
voice-port 0/1/1
 trunk-group ALL_FXO 62
 cptone SG
 description Configured by CCA 4 FXO-0/1/1-Custom-BG
 caller-id enable
voice-port 0/1/2
 trunk-group ALL_FXO 63
 cptone SG
 description Configured by CCA 4 FXO-0/1/2-Custom-BG
 caller-id enable
voice-port 0/1/3
 trunk-group ALL_FXO 64
 cptone SG
 description Configured by CCA 4 FXO-0/1/3-Custom-BG
 caller-id enable
voice-port 0/4/0
 auto-cut-through
 signal immediate
 input gain auto-control -15
 description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 4.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate profile 1 register confprof1
 associate profile 2 register mtp001b8fac16a0
dspfarm profile 2 transcode
 description CCA transcoding for SIP Trunk DIDLogic
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 maximum sessions 6
 associate application SCCP
dspfarm profile 1 conference
 description DO NOT MODIFY, active CCA conference profile - CCA2.0 codec711
 codec g711ulaw
 codec g711alaw
 maximum conference-participants 32
 conference-join custom-cptone CCAjointone
 conference-leave custom-cptone CCAleavetone
 shutdown
dial-peer cor custom
 name internal
 name local
 name local-plus
 name international
 name national
 name national-plus
 name emergency
 name toll-free
dial-peer cor list call-internal
 member internal
dial-peer cor list call-local
 member local
dial-peer cor list call-local-plus
 member local-plus
dial-peer cor list call-national
 member national
dial-peer cor list call-national-plus
 member national-plus
dial-peer cor list call-international
 member international
dial-peer cor list call-emergency
 member emergency
dial-peer cor list call-toll-free
 member toll-free
dial-peer cor list user-internal
 member internal
 member emergency
dial-peer cor list user-local
 member internal
 member local
 member emergency
 member toll-free
dial-peer cor list user-local-plus
 member internal
 member local
 member local-plus
 member emergency
 member toll-free
dial-peer cor list user-national
 member internal
 member local
 member local-plus
 member national
 member emergency
 member toll-free
dial-peer cor list user-national-plus
 member internal
 member local
 member local-plus
 member national
 member emergency
 member toll-free
dial-peer cor list user-international
 member internal
 member local
 member local-plus
 member national
 member emergency
 member toll-free
dial-peer voice 1 pots
 destination-pattern 204
 port 0/0/0
 no sip-register
dial-peer voice 2 pots
 destination-pattern 203
 port 0/0/1
 no sip-register
dial-peer voice 3 pots
 destination-pattern 202
 port 0/0/2
 no sip-register
dial-peer voice 4 pots
 destination-pattern 201
 port 0/0/3
 no sip-register
dial-peer voice 5 pots
 description ** MOH Port **
 destination-pattern ABC
 port 0/4/0
 no sip-register
dial-peer voice 6 pots
 description tcatch all dial peer for BRI/PRIv
 translation-profile incoming nondialable
 incoming called-number .%
 direct-inward-dial
dial-peer voice 50 pots
 description ** incoming dial peer **
 incoming called-number ^AAAA$
 port 0/1/0
dial-peer voice 51 pots
 port 0/1/1
dial-peer voice 52 pots
 port 0/1/2
dial-peer voice 53 pots
 port 0/1/3
dial-peer voice 54 pots
 description ** FXO pots dial-peer **
 destination-pattern A0
 port 0/1/0
 no sip-register
dial-peer voice 55 pots
 destination-pattern A1
 port 0/1/1
 no sip-register
dial-peer voice 56 pots
 destination-pattern A2
 port 0/1/2
 no sip-register
dial-peer voice 57 pots
 destination-pattern A3
 port 0/1/3
 no sip-register
dial-peer voice 2000 voip
 description ** cue voicemail pilot number **
 destination-pattern 100
 b2bua
 session protocol sipv2
 session target ipv4:10.1.10.1
 voice-class sip outbound-proxy ipv4:10.1.10.1
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 1000 voip
 permission term
 description ** Incoming call from SIP trunk (DIDLogic) **
 session target sip-server
 voice-class codec 1
 voice-class sip dtmf-relay force rtp-nte
 dtmf-relay rtp-nte
 fax rate 14400
g711ulaw
 ip qos dscp cs5 media
 ip qos dscp cs4 signaling
 no vad
dial-peer voice 1001 voip
 corlist outgoing call-local
 description ** star code to SIP trunk (DIDLogic) **
 destination-pattern *..
 voice-class codec 1
 dtmf-relay rtp-nte
 fax rate 14400
g711ulaw
 no vad
dial-peer voice 1003 voip
 description ** Passthrough Inbound Calls for PSTN from CUE **
 b2bua
 incoming called-number ABCDT
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 1005 voip
 description ** Passthrough Inbound Calls for MWI from CUE **
 b2bua
 incoming called-number A80T
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 1009 voip
 description ** Passthrough Inbound Calls for Internal Extensions from CUE **
 b2bua
 incoming called-number ^...$
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 1002 voip
 preference 1
 session target dns:sip.hk.didlogic.net
 voice-class codec 1
 dtmf-relay rtp-nte
 fax rate 14400
g711ulaw
 no vad
dial-peer voice 99 pots
 service stcapp
 port 0/0/3
 forward-digits 0
dial-peer voice 58 pots
 trunkgroup ALL_FXO
 description **CCA*Local+Int'l*Local**
 translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
 preference 5
 destination-pattern 9[1-9]T
 forward-digits all
 no sip-register
dial-peer voice 1020 voip
 corlist outgoing call-international
 description **CCA*Local+Int'l*International**
 translation-profile outgoing PSTN_Outgoing
 preference 2
 destination-pattern 8[1-9]T
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 1021 voip
 preference 1
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 3000 voip
 description Incoming_US-BG
 translation-profile incoming Incoming_US-BG_Called_4
 incoming called-number 1713*******6
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 3001 voip
 description Incoming_AU-BG
 translation-profile incoming Incoming_AU-BG_Called_5
 incoming called-number 61********5
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 3002 voip
 description Incoming_UK-BG
 translation-profile incoming Incoming_UK-BG_Called_6
 incoming called-number 44*********2
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
no dial-peer outbound status-check pots
sip-ua
 credentials username 05917 password 7 003E401454585 realm sip.sg.didlogic.net
 credentials username 93267 password 7 033E0819560C7 realm sip.sg.didlogic.net
 credentials username 55140 password 7 046158145F221 realm sip.sg.didlogic.net
 keepalive target dns:sip.sg.didlogic.net
 authentication username 05917 password 7 023C57495B055 realm
sip.sg.didlogic.net
 no remote-party-id
 retry invite 2
 retry register 10
 timers connect 100
 timers keepalive active 100
 registrar dns:sip.sg.didlogic.net expires 3600
 sip-server dns:sip.sg.didlogic.net
 connection-reuse
 host-registrar
telephony-service
 sdspfarm conference mute-on 111 mute-off 222
 sdspfarm units 5
 sdspfarm transcode sessions 6
 sdspfarm tag 1 confprof1
 sdspfarm tag 2 mtp001b8fac16a0
 conference hardware
 video
 fxo hook-flash
 max-ephones 14
 max-dn 56
 ip source-address 10.1.1.1 port 2000
 auto assign 1 to 1 type bri
 calling-number initiator
 service phone videoCapability 1
 service phone ehookenable 1
 service phone webAccess 0
 service dnis overlay
 service dnis dir-lookup
 service dss
 timeouts interdigit 2
 system message UC520
 url services http://10.1.10.1/voiceview/common/login.do
 url authentication http://10.1.10.2/CCMCIP/authenticate.asp
 load 521G-524G cp524g-8-1-17
 time-zone 43
 date-format dd-mm-yy
 keepalive 30 auxiliary 4
 voicemail 100
 max-conferences 8 gain -6
 call-forward pattern .T
 call-forward system redirecting-expanded
 moh flash:/media/music-on-hold.au
 multicast moh 239.10.16.16 port 2000
 web admin system name cisco secret 5 $1$7PJ3$MLovPhyY/TvmgYJc72WwI/
 dn-webedit
 time-webedit
 transfer-system full-consult dss
 transfer-pattern 9.T
 transfer-pattern .T
 secondary-dialtone 9
 night-service day Sun 17:00 09:00
 night-service day Mon 17:00 09:00
 night-service day Tue 17:00 09:00
 night-service day Wed 17:00 09:00
 night-service day Thu 17:00 09:00
 night-service day Fri 17:00 09:00
 night-service day Sat 17:00 09:00
 fac standard
 create cnf-files version-stamp 7960 Jul 27 2014 00:27:04
ephone-template  15
 url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
 softkeys remote-in-use  Newcall
 softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
 softkeys seized  Cfwdall Endcall Redial Pickup Meetme Gpickup Callback
 softkeys connected  Hold Endcall Trnsfer Confrn ConfList RmLstC Acct Park Select Join
 button-layout 7931 2
ephone-template  16
ephone-template  17
 softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  1  octo-line
 number 205 no-reg primary
 label Wireless Phone
 name Wireless Phone
ephone-dn  9
 number BCD no-reg primary
 description MoH
 moh out-call ABC
ephone-dn  42  octo-line
 number 770 no-reg primary
 conference meetme unlocked
 preference 3
ephone-dn  43  octo-line
 preference 2
 no huntstop
ephone-dn  44  octo-line
 preference 1
 no huntstop
ephone-dn  45  octo-line
 no huntstop
ephone-dn  46  octo-line
 number C001 no-reg primary
 conference ad-hoc
 preference 3
ephone-dn  47  octo-line
 conference ad-hoc
 preference 2
 no huntstop
ephone-dn  48  octo-line
 conference ad-hoc
 preference 1
 no huntstop
ephone-dn  49  octo-line
 conference ad-hoc
 no huntstop
ephone-dn  54
 number 300 no-reg primary
 park-slot timeout 30 limit 2 transfer 700 retry 30 limit 2
 label Call Park
ephone-dn  55
 number A801... no-reg primary
 mwi off
ephone-dn  56
 number A800... no-reg primary
 mwi on
ephone  1
 device-security-mode none
 mac-address B8FA.C16A.0003
 ephone-template 16
 max-calls-per-button 2
 username "WiPhone" password cisco
 type anl
 button  1:1
alias exec cca_voice_mode PBX
alias exec cca_vm_notification schedule from_time=00 to_time=24
banner login ^CCisco Configuration Assistant. Version: 3.2 (3). Sat Jul 05 11:16:36 SGT
2014^C
line con 0
 no modem enable
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
line vty 0 4
 transport input all
line vty 5 100
 transport input all
ntp master
ntp peer 192.168.1.1
ntp peer pool.ntp.org
end
UC520#
11 Replies 11
Leo Laohoo
Post removed due to low score.
I post with good intention.  A low score means the possibility of an incorrect response.
Hi Leo, what dialing route specifically? if you can give an example that would be great.
currently, the only control i have is this one authentication i have under sip-ua. authentication using dial-peers doesn't seem to work for me.
I have read that link before, from what i understand it only helps you for redundancy but no advice on how to control which account to use
Hi.
That's not only for redundancy, but also for path preference.
Infact using preference keyword under dial-peer with the same destination pattern, vg will select dialpeer based on priority
Carlo
Please rate all helpful posts "The more you help the more you learn"
Thanks Carlo for your reply.
I have read again the link and you are correct that in using the preferred command together with localhost under POTS dial-peer, I can now select which correct path to choose for my outbound calls. I'm just not very strong with dial-peer and translation rules at the moment.
I will try this solution during the weekend and let you know. But it would have been better if there was a sample configuration for this option.
all those options are also available on CME through translation rules and dial-peer routing, however i am not able to select which type of sip account to use since it's under one sip provider. if it was under two different providers then it would have been possible AFAIK
rlaudiano
anybody else can help with this?
anyone?
rlaudiano
I have updated the first post with the configuration.
Would really appreciate it if anybody can help solve my problem or guide me to the right solution.
