How to correct reverse DNS error on utils diagnose test?
             We were working an issue in our Publisher and Subscribers and performed a "utils diagnose test" on each through the command line.  It passed everything but reverse dns lookup.  Does anyone know how to fix that type error?  Thanks in advance.  We are running CUCM 8.6(2a)SU3.
1 ACCEPTED SOLUTION
VIP Super Bronze
Yes and it's important there is only one PTR record per IP address. If you're using a non-Windows DNS infrastructure it's likely to look more like this:
10.10.250.10.in-addr.arpa   PTR  cmp1.hs.uab.edu
Note that the IPv4 octets are reversed.
Please remember to rate helpful responses and identify helpful or correct answers.
Just make sure they're properly added in the forward and reverse lookup zones in your DNS.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
How do we find out what the test is trying to lookup in dns that is failing?  Our network group  provided the following.
c:\Windows\System32>dig +short -x 10.250.10.10
cmp1.hs.uab.edu
Your DNS Admins will need to add the reverse lookup for your server. Example below
Forward Lookup
A cucmpub.local 10.0.0.1
Reverse Lookup
PTR 10.0.0.1 cucmpub.local
Yosh
HTH Regards, Yosh
Can you please provide the entry they will need to for us for the following?
10.250.10.10 is the ip address of the publisher.
cmp1.hs.uab.edu is the host name
Jeff
PTR 10.250.10.10 cmp1.hs.uab.edu
Yosh
HTH Regards, Yosh
To clarify, we would need the following entries???
PTR 10.250.10.11 cms1.hs.uab.edu
PTR 10.250.10.12 cms2.hs.uab.edu
PTR 10.250.10.13 cms3.hs.uab.edu
PTR 10.250.10.14 cms4.hs.uab.edu
Jeff
VIP Super Bronze
Jonathan,
+5 that's some good information.
Yosh
HTH Regards, Yosh
Hi Jonathan,
Hi Jonathan,
Nice instruction. We have added like this 10.10.250.10.in-addr.arpa.  PTR  cmp1.hs.uab.edu.com for reverse lookup in centos dns server. but unfortunately fail in reverse lookup while we dig for testing (But forward lookup is OK). In cucm server an error 'DNS server unreachable' is showing. 'Reverse Lookup DNS failed' is showing debug test.
But  this type of problem is not heppening in windows server.
Would you/anybody can help me the solution.
Thanks in advance and i'll give rate 5 :)
Nizam
VIP Super Bronze
What I typed above is how the
What I typed above is how the PTR record should look when queried from a tool such as dig. Creating the record is more involved than that. For example, you will likely need to create a zone file and reference it in named.conf and then define the PTR record within that. Ask your DNS admin for assistance here.
Yosh/Jonathan - You were both correct.  What we found was they needed our ad entry added not just our hs entry.  We changed the names to cmp1.ad.hs.uab.edu and it worked.  We have also pointed cmp1.hs.uab.edu to the ad entry to ensure we don't miss any possible entries.
Thank you both for the assistance.
Jeff
1171
