how to create a lot to see who has log on to the CUCM 9
is there any way that can keep track of who has been log on to the cucm administrator page and make changes on cucm 9 based on the user login name?
many thanks
Rachel
VIP Gold
You can collect the Audit
You can collect the Audit logs using RTMT to see any configuration changes performed on CUCM and by whom and which IP.
Suresh
Hi I have tried to set it up
I have tried to set it up as per the screen shot, however when I tried to download it, even though i can see the log file, and also the size of the file is not 0, however it keep saying file file does not exist....
I tried both browse on the viewer and also download it, there is no file can be downloaded...
any idea?
Rachel
Hello Rachel,Did you try to
Hello Rachel,
Did you try to access the audit.log through CUCM CLI.
Can you try using and see are you able to so
Below is the command to check the file
login to CLI
file list activelog audit/AuditApp/* date detail
Shows last 10 logs messages from the Audit file
file tail activelog audit/AuditApp/Auditxxxxx.log
pertaining to RTMT issue, looks like you user do not have write access permission
c:\Program Files\Cisco directory.
Br,
Nadeem
Br, Nadeem Please rate all useful post.
I now can open the file,
I now can open the file, however it only has the time.... but didnt have the username to indicate who has logged on....
<?xml version="1.0"?>
-<QueryResult> -<Node name="10.200.10.10"> <TokenID>1402625972246</TokenID> -<ServiceList> -<ServiceName name="Cisco Audit Logs"> -<FileType name="informixauditlogs"> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.20" size="9999967" modifiedDate="Tue Aug 19 12:42:56 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.21" size="9999978" modifiedDate="Tue Aug 19 12:44:37 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.22" size="9999931" modifiedDate="Tue Aug 19 12:46:30 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.23" size="9999907" modifiedDate="Tue Aug 19 12:49:38 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.24" size="9999925" modifiedDate="Tue Aug 19 12:53:02 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.25" size="9999931" modifiedDate="Tue Aug 19 12:53:50 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.26" size="9999884" modifiedDate="Tue Aug 19 12:56:46 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.27" size="9999948" modifiedDate="Tue Aug 19 13:01:58 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.28" size="9999991" modifiedDate="Tue Aug 19 13:07:57 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.29" size="9999931" modifiedDate="Tue Aug 19 13:10:00 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.30" size="9999895" modifiedDate="Tue Aug 19 13:17:27 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.31" size="9999943" modifiedDate="Tue Aug 19 13:28:55 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.32" size="9999893" modifiedDate="Tue Aug 19 13:39:01 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.33" size="9999878" modifiedDate="Tue Aug 19 13:41:31 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.34" size="9999880" modifiedDate="Tue Aug 19 13:49:27 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.35" size="9999924" modifiedDate="Tue Aug 19 13:59:38 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.36" size="9999997" modifiedDate="Tue Aug 19 14:10:41 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.37" size="9999910" modifiedDate="Tue Aug 19 14:22:01 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.38" size="9999982" modifiedDate="Tue Aug 19 14:33:38 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.39" size="9999974" modifiedDate="Tue Aug 19 14:44:43 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.40" size="9999993" modifiedDate="Tue Aug 19 14:53:11 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.41" size="9999997" modifiedDate="Tue Aug 19 15:03:51 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.42" size="9999885" modifiedDate="Tue Aug 19 15:14:52 EST 2014"/> <FileName name="/var/log/active/audit/informixauditlogs/oc_hub_pub_ccm9_0_1_10000_37.43" size="5571892" modifiedDate="Tue Aug 19 15:19:41 EST 2014"/> </FileType> -<FileType name="AuditApp"> <FileName name="/var/log/active/audit/AuditApp/Audit00000036.log" size="1422908" modifiedDate="Tue Aug 19 15:19:41 EST 2014"/> </FileType> -<FileType name="vos"> <FileName name="/var/log/active/audit/vos/vos-audit.log" size="8593627" modifiedDate="Tue Aug 19 15:19:25 EST 2014"/> </FileType> </ServiceName> </ServiceList> </Node> </QueryResult>
is there way to find out what user has log on?
Rachel
Hello Kindly check the
Hello
Kindly check the attached file for audit logon using RTMT.
please rate all useful informaion
any idea?
Rachel
Hi Kindly check the
Kindly check the permissions for the user .
please rate all useful information
83
