How to create restriction codes on ip phones?
Hi all,
  My scenario is something like this: In my company i have "Cisco call manager express" i have 20 ip phones in which one is in guest room, i want to restrict only that single phone with access code while making international calls, meanwhile, only Manager can make international calls with that phone, so only manager will have that access code no one can make international calls.
How i can configure this scenario? please help me.
Thanks in advance.
Hall of Fame Super Gold
Re: How to create restriction codes on ip phones?
This is asked very frequently, try searching with the box on the right side.
hi
as paolo said there are alot of resources in netpro regarding what you asking about
you can search it by using key words like  cme cor list
also you can use the bellow link as an example
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
good luck
if helpful Rate
221
