how to determine the number of in and outbound calls?
Hi all,
I am looking for a possibility to analyze or summarize how much calls in a certain peroid of time are inbound and are outbound.
We want to devide or connection into Sip-Trunks and E1/Pri. Sip Trunks for outbound and E1/Pri for inbound and want to calculate the SIP-Connection needed for this.
Is there a way in Callmanager 6.1 ?
kind regards
Christian
Re: how to determine the number of in and outbound calls?
Enable CDR from serviceability page then you will gather statistics you need.
Thanks for your reply,
unfortunally on this cluster we do not have CDR enabled.
Seems as if I have to do that on a weekend :-(
greetings
Chris
133
