02-21-2012 06:47 AM - edited 03-16-2019 09:41 AM
Could someone be kind enough to tell me how to disable intercom once it has been set up please? Any help would be greatly appreciated as a client requires it disabled.
Am using CUE V7 if that is any help?
Solved! Go to Solution.
02-21-2012 06:55 AM
Remove the button from the phone.
Is this CUCM or CME as CUE is a voicemail and irrelevant here.
Chris
02-21-2012 10:12 AM
OK, remove the intercom button from the ephon configuration, so if intercom button is number 2 on the phone and your config looks somthign like this:
ephone 1
button 1:1 2:10
change it to:
ephone 1
button 1:1
Here is admin doc:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeinter.html
HTH,
Chris
02-21-2012 10:25 AM
NP, hopefully it worked for you.
Please remember to rate all useful posts!
Chris
02-22-2012 06:23 AM
Well, that means you do not have any intercoms setup, so there is nothing to disable. Perhaps you misunderstood the feature they are using. What needs to be removed? Either way the way you remove it is identify which button it is on which ephone and then issue:
ephone 5
no button X:Y
where X is button location (i.e. 2 for second button on the phone) and Y is the ephone-dn you need to remove.
Chris
02-21-2012 06:55 AM
Chris
02-21-2012 09:35 AM
Thanks Chris, sorry I feel like a bit of a fool to ask but am a routing n switching eng and not touched Cisco IP phones.
What are the steps to remove the button from the phone?
rgds
ROB
02-21-2012 09:37 AM
Is this CallManager or CallManager Express? If you are not sure, is it running on a server or on a router?
Chris
02-21-2012 10:05 AM
CUE version7 (so express) and running on a 2851
02-21-2012 10:12 AM
ephone 1
button 1:1 2:10
change it to:
ephone 1
button 1:1
Here is admin doc:
HTH,
Chris
02-21-2012 10:20 AM
Thanks Chris, Have a good day mate...
Rob
02-21-2012 10:25 AM
Chris
02-21-2012 10:52 AM
OK, slightly premature. But hey, nearly there. Have had a look at the router and there 1-48 ephones config'd
ephone 24
device-security-mode none
video
mac-address 001E.4A0B.E398
after-hours exempt
username "TSargeant"
paging-dn 1
type 7941
button 1:61 2:20
ephone 40
mac-address 001E.4A34.4A02
username "sample"
paging-dn 1
type 7941
button 1:41 2:61
so is it the second number on the button that represents the intercom? Seems I am unable to use that link you sent me..
02-21-2012 10:55 AM
Please post configuration for ephon-dn 61, 20, 41
Chris
02-21-2012 11:04 AM
Chris, here you are as requested.
ephone-dn 20
number 319 secondary 5097
label Help Desk. x319
description "sample" x319
name sample
preference 1
call-forward busy 600
call-forward noan 600 timeout 20
corlist incoming user900-international
hold-alert 30 originator
ephone-dn 41 dual-line
number 340 secondary 5090
label Carol L. x340
description "sample" x340
name sample
call-forward all 600
ephone-dn 60 dual-line
number 850
description Meet-Me Conference DN
conference meetme
preference 3
no huntstop
02-21-2012 11:09 AM
Also Chris, this was another ephone config'd
ephone 33
video
mac-address 001E.F728.2FC4
username "Sample" password null
type 7961 addon 1 7914 2 7914
auto-line 2 answer-incoming
button 1:34 2:39 3:31 4:43
button 5:44 6:40 7w12 8w38
button 9w14 10w7 11w9 12w30
button 13w22 14w32 15w4 16w37
button 17w23 18w10 19w61 20w26
button 21w56 22w11 23w5 24w18
button 25w62 26w13 27w25 28w33
button 29w27 30w8 31w19 32w49
button 33w16 34w69
02-21-2012 12:06 PM
So, which phone do you need to remove the itnercom from?
Chris
02-21-2012 04:36 PM
Chris, all of them please mate.
Rob
02-21-2012 04:47 PM
Identify which ephone-dns have "intercom ephone-dn" configured, i.e.
ephone-dn 18
number 5001
name "intercom"
intercom 5002 barge-in
ephone-dn 19
name "intercom"
number 5002
intercom 5001 barge-in
then identify which ephones reference it, i.e:
ephone 4
button 1:2 2:18
ephone 5
button 1:4 2:19
and remove the button association:
ephone 4
no button 2:18
ephone 5
no button 2:19
HTH,
Chris
