How to disable the speaker for one IP phone?
CME 4.1
one 7961, several 7941 and 7911
The 7961 is for reception. The customer wants only disable the speaker on 7961.
But the service parameters in the telephone-service configuration are applied to all phones. How can I disable only one phone's speaker?
Thanks!
Bronze
Re: How to disable the speaker for one IP phone?
I'm running CCM 4.1(3) and if you pull up a device you can click the checkbox to disable the speaker phone. And since you are pulling up a device to do it, it's only gonna affect that one device.
Yes, it is easy to disable a speaker on any IP Phone in CCM4.x or 5.x.
But my system is CallManager Express 4.1, I have no idea how to disable one(only one) phone's speaker.
Hall of Fame Super Red
Hi Michael,
This can be done on CME on a phone by phone basis. Have a look;
service phone
To modify the vendorConfig parameters in the configuration file, use the service phone command in telephony-service or ephone-template configuration mode. To disable a setting, use the no form of this command.
service phone parameter-name parameter-value
no service phone parameter-name parameter-value
This command in telephony-service configuration mode modifies vendorConfig parameters in the configuration file for phones in a Cisco Unified CME system.
In Cisco Unified CME 4.0 and later versions, support for creating configuration files at a per-phone level was supported and this command in ephone-template configuration mode creates an ephone-template of vendorConfig parameters which can then be applied to an individual Cisco Unified IP phone in Cisco Unified CME.
disableSpeaker {true | false}
Enables and disables the speakerphone.
true Enabled (default).
false Disabled.
Router(config)# telephony-service
Router(config-telephony)# service phone disableSpeaker false
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_command_reference_chapter09186a008061137f.html#wp1123331
The following example shows how to disable the Speakerphone on an individual IP phone (ephone 15) using an ephone template:
Router(config)# ephone-template 8
Router(config-ephone-template)# service phone disableSpeaker false
Router(config-ephone-template)# exit
Router(config)# ephone 15
Router(config-ephone)# ephone-template 8
Router(config-ephone)# exit
Router(config-telephony)# create cnf-files
Router(config-telephony)# exit
Router(config-ephone)# reset
Hope this helps!
Rob
Thanks a lot Rob.
I tried the configuration but it doesn't work. The speaker is always enabled.
I also tested the configuration with the settingsAccess key(0--disable), same problem(always enabled). Maybe there are other problems which I don't know.
Michael
Bronze
On a physical phone, press settings- go to network configuration - enter 45 or 44 depending upon model (handset
only mode) - press **# you see your options on the soft key. handset only mode=Yes will
disable speaker phone. Save - exit.
Thanks.
The solution works with 7940/7960, but there is no "handset only mode" configuration on 7941/7961. I can see "Handset Enable Yes" and "Speaker Enable Yes" in the "Media Configuration", which is one of sub-menu of "Device Configuration". It looks like I can't change the setting because there is no softkey available on the display.
I had the exact same problem that you have. I resolved this issue by doing two things.
First, the Cisco documentation with regards to "disableSpeaker {true | false}" seems to be backwards or my thinking is, not sure which. Anyhow, I found that changing it to "true" actually disabled the speaker.
Example:
Router(config-ephone-template)# service phone disableSpeaker true
Secondly, by default CME 4.0 and above ignores vendorcfg entries when using the default phone profile located on default file system (system:). To use ephone templates with CME 4.0 and above you have to reconfigure so CME uses per phone profiles located on another files system such as flash:.
Example:
Router(config-telephony)#cnf-file location flash:
Router(config-telephony)#cnf-file perphone
This enables CME to create individual cfg files for each phone. Vendorcfg entries assigned by the ephone templates are placed in these files where it can correctly be read by the phones.
Here is what I ended up using and everything seems to be working fine:
Router(config)#ephone-template 10
Router(config-ephone-template)#service phone disableSpeaker true
Router(config-ephone-template)#exit
Router(config)#ephone 2
Router(config-ephone)#ephone-template 10
Router(config-ephone)#exit
Router(config)#telephony-service
Router(config-telephony)#create cnf-files
Router(config-telephony)#exit
Ref docs:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00808777f8.html#wp1028761
I hope this helps.
Gary
Hall of Fame Super Gold
Great info Gary, especially the about hot to make the custom settings work properly in per-phone mode. I've rated this post a'5'.
This is what I have been trying to find for weeks! Thank you so much!!!!!
4639
