How to disable Tone on-Hold in CME
I want to know is there any way to disable tone on-hold in CME.When user presses hold button when they are on conference every predetemined interval they are hearing 5 beep tones.In Callmanager there is an option to change it but in CME i have no idea.
Re: How to disable Tone on-Hold in CME
Hi harikrishnan,
Use a silent wav file as a MOH source for the group you need, so they will hea nothing
wish this be helpful
Hall of Fame Super Gold
I don't think this a good idea, first of all, you may want have a regular MoH instead of silence, as there are no MoH groups in CME, then MoH is not used for internal calls.
What is the use of Hold-alert under ephone-dn is there any relation with this but i tried it out this as well but no luck.
That is to alert you back you have call on hold, hence unrelated.
768
