how to disable voice-port 0/0/0 and others
I have a 2801 router that used to run CCM. It no longer requires any voices services and the voice service is now outsourced. How do I remove these voice ports:
voice-port 0/0/0
voice-port 0/0/1
caller-id enable
voice-port 0/0/2
caller-id enable
voice-port 0/0/3
caller-id enable
voice-port 0/1/0
caller-id enable
voice-port 0/1/1
caller-id enable
voice-port 0/1/2
caller-id enable
voice-port 0/1/3
Thank you,
1 ACCEPTED SOLUTION
You can admin down them (doing a shut), but to remove them fully, remove the cards  (assuming these are 4FXS or FXO ports). also you might want to remove the DSP modules in the router.
Please remember to rate useful posts, by clicking on the stars below.
Hall of Fame Super Gold
Why a 100% correct answer, made with the will to help had been rated just a "3". I've rated it again to partially compensate.
1160
