Anonymous
N/A
How to disconnect an active call?
Is there a command that will allow me to disconnect an active call in an IOS gateway without disrupting everyone using the PRI?
Josh
Re: How to disconnect an active call?
try a shut on the actual channel
voice-port 0/0/0:23.1
shut
Have not done this, I dont think, but it may work
Hall of Fame Super Gold
No it doesn't. First the .1 notation refers to a subinterface that doesn't exists, then the only voice port that exist is 0/0/0:23, not 0/0/0:1.
I am not talking about the serial subinterface. I just verified on my 2811 running c2800nm-spservicesk9-mz.123-11.T10.bin that when i go to config mode and then type voice-port 0/0/0:23.1 i can enter the channel and puts me in config-voiceport mode. You actually have most of the config commands that you would for a normal voice-port. I remembered this because I had to busyout a particular channel before
You are right, I have tried and one can enter a notation indicating a timeslot after dot, however is taken as a synonymous for the port without the dot, so you end shutdown the D channel.
Try "show call active voice comapct", find ID, then clear call voice causecode 1 calling-number XXX. There is also an ID option.
Not sure if that works if you're using MGCP. If you have a badly stuck call however the above is not enough.
184
