Community Member
how to easily combining SCCP and H323..
Hello, i am trying to integrate telephony-service sccp to fxo,fxs port(h323).. how to do that? so far i only can talk in one direction only calling from sccp phone to analog phone so i hear my friend talked to me but he could not hear me... i am using two cisco router. one router is running scpp then another router just fxo and fxs port. i have created dialpeer. anyone wants help? thankyou ;)
Re: how to easily combining SCCP and H323..
Please include the configs and also which phone (DN) you are calling from and to.
Community Member
Thanks...
===> Router running SCCP =====<
all sccp to sccp is ok but sccp to h323 is bad.. i use ephone 30 and try to connect another h323 cisco 1700 with dial number 900 and 901.. the phone at h323 is ringing but voice is only one direction from sccp to h323
Current configuration : 6374 bytes
version 12.4
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps log datetime msec localtime
service password-encryption
service compress-config
boot-start-marker
boot system flash:c2800nm-ipvoice_ivs-mz.124-4.XC2.bin
boot-end-marker
logging buffered 512000 debugging
enable secret 5 $1$N9O1$aSXLorkV7Gc57Sq8wMHvA1
aaa new-model
aaa authentication login default local
aaa accounting connection h323 start-stop group radius
aaa session-id common
resource policy
clock timezone IND_WST 7
ip cef
ip flow-cache timeout inactive 10
ip flow-cache timeout active 5
voice-card 0
no dspfarm
voice rtp send-recv
voice service voip
h323
call start slow
dial-peer voice 12 voip
destination-pattern 900
session target ipv4:172.23.15.222
dtmf-relay h245-alphanumeric
dial-peer voice 901 voip
destination-pattern 901
dial-peer voice 7 pots
destination-pattern 600
port 0/3/3
dial-peer voice 235 voip
gatekeeper
shutdown
telephony-service
video
no auto-reg-ephone
load ATA ATA030100SCCP040211A.zup
max-ephones 52
max-dn 192
ip source-address 172.23.17.5 port 2000
service phone videoCapability 1
keepalive 45
max-conferences 8 gain -6
call-park system redirect
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1 dual-line
number 20127
ephone-dn 3 dual-line
number 20128
ephone-dn 30
number 777
ephone 1
description CIT-Jakarta
mac-address 0019.0670.E9F6
codec g729r8
type ata
button 1:1
ephone 23
description SNP-Banjarmasin
mac-address 0019.0670.EA3D
codec g729r8
type ata
button 1:23
ephone 30
video
mac-address 0010.22FF.BD45
cisco 1700
iam sorry for 1700 config already erased...but
it's only analog phone at fxs and have dialpeer to sccp router..
firewall has been fully opened between this all devices(scpp phone and 2 two router)...
is there easy guidance for this scenario(sccp and h323 router? Tx...
Hall of Fame Super Gold
if you have one-way audio and a FW in between, be assured the latter is the cause of the problem.
If cannot configure the FW to allow voice, what you can do set-up and GRE tunnel on your router. this way all your traffic will flow withing one single port. On the FW, permit IP protocol 47 (GRE). On the routers:
interface tunnel 0
ip address
tunnel source
tunnel destination
then configure all voip to use tunnel addresses.
Hope this helps, if so please rate post!
174
