How to eject the DVD from CUC
I need to reboot the CUC server in which i have just upgraded the Patch through SFTP. Before that i had inserted the Bootable DVD (Patch 8.6.2). Its still connected to the server, now i need to remove/eject the DVD from the DVD Drive which is connected to Server.
Any command to eject the dvd ?? I referred all Cisco guides, it says do it physically but the
Pls suggest.
1 ACCEPTED SOLUTION
There's no command to eject the disk tray, you need to go to the server, and press the eject button
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
java
java
If you have ILO(Integrated Lights-Out) access to this server ..then change the booting sequence order CD/DVD to HDD from BIOS setting. So after server restart, server will bootup with CUC OS.
Bhushan
Hall of Fame Super Silver
What is the server manufacturer?
Chris
Unlucky, i dont have ILO configured and Server model is MCS 7825 H2 .... HP Server.
245
