how to enable CMRs
hi, i've already enabled the CDRs, and they are comming fine to the sftp server, but i dont see the CMRs, what else do i need?
  • IP Telephony
1 ACCEPTED SOLUTION
Re: how to enable CMRs
You mention you enabled CDR, but did you enabled CMRs??
Enabling CDR does not enable automatically CMR.
You need to change the Call Diagnostics Enabled parameter to TRUE to get CMRs.
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
java
java
120
