How to enable password to join in a MeetMe conference?
Arnab Mukherjee
Can anyone please let me know how to configure password for MeetMe conference? I wnat to prompt a password everytime a user will be trying to join in a meetMe conference. Otherwise there will be a chance that a user dial any meetme number unknowingly and he joined in to the bridge. Loking for your help. ..
Arnab Mukherjee
Jaime Valencia
Please search before asking, this has been asked hundreds of times.
Short answers, there is no way todo this with CUCM.
Your options are either use CUC/Unity to front end the meetme and announce who's trying to join (if you're interested, search CSC for detailed instructions)
Or if you really want a PIN you'll need to do something with UCCX/UCCE or TCL scripting.
java
if this helps, please rate
