Community Member
How to enable USB port on SIP 8961 phone on CME 9.0?
In Cisco CME 9.0, how do you enable the USB port on the 8961 phone handsets for headset usage?
It worked fine in the default phone shipping configuration until I created proper per-phone profiles under voice register on the tftp server.. so something they downloaded in their configuration must have broke/disabled it.
Of course, the documentation tells you how to do it in CUCM but not CME.
Community Member
I have the same issue, have you found the solution?
Thank you
Try:
telephony service  service
phone headsetWidebandEnable 0
no create cnf-files
create cnf-files
voice register global
no create  profile
create  profile
Then reset the voice register pool.
Give it a try and let us know.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Can you download the config file using TFTP utility on Windows so we can confirm the contents?
378
