How to enebel extension mobility
I just received lots of cisco 6921 phones.
When i add them to network they auto register but Enable Extension Mobility is turned off.
So how can I enable extension mobility by default so that phone auto register to be ready to use?
Ivan
1 ACCEPTED SOLUTION
It´s not possible to set that
It´s not possible to set that for auto-registered phones on your version.
java
if this helps, please rate
www.cisco.com/go/pdi
Assuming your using CUCM and
Assuming your using CUCM and not CME... ccmadmin -> Bulk Administration -> Phones -> Update Phones -> Query. Build a query to select the phones that you want. Then do "Next", and near the bottom you can configure EM. GTG
Please rate all helpful posts.
Thanks for response.Yes we
Yes we use CCUM, but that I can do when the phones are already added to network.
I just want to add phones and username and password to user, and when the put them out of box that they can use it immediately…
VIP Super Bronze
You need to configure
You need to configure |Extension Mobility Profiles (device profiles). You also need to configure EM service. You then need to associate users to their EM profiles and subscribe your phones to the EM service. Once all this is done, your users can login to the phone and use EM
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi, i know that.All i want is
i know that.
All i want is to have on new auto registred phones enabled extension mobility checkbox by default  :-)
java
(No subject)
sad
Ivan, With CUCM 10.0, you can
Ivan,
With CUCM 10.0, you can configure default device templates for auto-registration such that extension mobility will automatically be enabled.
I'm not sure of a way to do this pre-10.0.
Brian
Hi Brian, thanks for
Hi Brian,
thanks for sugestion but in CCM 7.1.5 there is no enable extension mobility in device template :-(
Ivan
115
