How To Extend the Duration of Call Forward NoAnswer on CME
I have a CME installation (v4.x) installed at a seniors home.  The forward to vmail is too quick for most of them.  I know you can change the forward for individual phones by using the command:
  • call-forward noan [voicemail number]timeout 10
Does anyone know if there's a system wide parameter on CME to extend the cf noan time for all phones at once?
Dave
2 ACCEPTED SOLUTIONS
Re: How To Extend the Duration of Call Forward NoAnswer on CME
Hello Dave,
In CME this needs to specify in the phone configuration with the command that you mention, unfortunately there is no way to configure this timeout in system wide form.
Please rate this post if was helpful
Walter Solano
CCVP, Cisco UCCX Specialist
Hall of Fame Super Red
Hi Dave,
Like my friend Walter nicely noted (+5 "W") there is no system-wide
setting for this type of change
call-forward noan
To configure call forwarding so that incoming calls to an extension (ephone-dn) that does not answer are forwarded to another number, use the call-forward noan command in ephone-dn or ephone-dn-template configuration mode. To disable call forwarding, use the no form of this command.
call-forward noan target-number timeout seconds
timeout seconds - Sets the duration that a call can ring with no answer before the call is forwarded to the target number. Range is from 3 to 60000. There is no default value.
From this good CME doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_c1ht.html#wp1063669
The only way to mitigate the scope of these changes (minimally) would be to use ephone-dn-template configuration mode.
Hope this helps!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Hello Dave,
Walter Solano
Hi Dave,
call-forward noan
Hope this helps!
Rob
563
