04-17-2018 04:08 AM - edited 03-17-2019 12:38 PM
the following show inventory come up with this
NAME: "Chassis", DESCR: "Cisco ISR4331 Chassis"
PID: ISR4331/K9 , VID: V04, SN:
NAME: "Power Supply Module 0", DESCR: "250W AC Power Supply for Cisco ISR 4330"
PID: PWR-4330-AC , VID: V02, SN:
NAME: "Fan Tray", DESCR: "Cisco ISR4330 Fan Assembly"
PID: ACS-4330-FANASSY , VID: , SN:
NAME: "module 0", DESCR: "Cisco ISR4331 Built-In NIM controller"
PID: ISR4331/K9 , VID: , SN:
NAME: "NIM subslot 0/1", DESCR: "NIM-1MFT-T1/E1 - T1/E1 Serial Module"
PID: NIM-1MFT-T1/E1 , VID: V05, SN:
NAME: "PVDM subslot 0/4", DESCR: "PVDM4-32 Voice DSP Module"
PID: PVDM4-32 , VID: V02, SN:
im trying to configure the voice gateway from scratch according to this document
but dont knonw how to find the slot , subslot , bay numbers for the E1 card? please help
Solved! Go to Solution.
04-17-2018 04:54 AM
It is easier than you think.
In my example, here is my sh inv.
NAME: "NIM subslot 0/1", DESCR: "NIM-4MFT-T1/E1 - T1/E1 Serial Module"
My NIM is on subslot 0/1. This means that each of my E1 port on that module will be numbered as follows depending on how many ports I have ( in my case it is 4)
So it will be e1 0/1/0, 0/1/1, 0/1/2 and 0/1/3
If you do a show diag, you get similar picture
sh diag sub 0/1 ee
SPA EEPROM data for subslot 0/1:
Product Identifier (PID) : NIM-4MFT-T1/E1
Version Identifier (VID) : V04
EEPROM data for slot 0 bay 1 daughter board 1
Product Identifier (PID) : PVDM4-256
Version Identifier (VID) : V02
Now you define your card type using your slot and subslot number based on the output of your sh inv. example: ( slot 0/subslot 1 and slot 0/subslot 2)
card type e1 0 1
card type e1 0 2
And finally you can see all my E1 controllers
controller E1 0/1/0
shutdown
pri-group timeslots 1-31
controller E1 0/1/1
shutdown
controller E1 0/1/2
controller E1 0/1/3
clock source line primary
In your example, you will define your config as follows
card type e1 0 1
and controller e1 0/1/0 ( you only have one port)
04-17-2018 04:19 AM
your e1 controller is in 0/1 as your output shows.
04-17-2018 04:54 AM
sh diag sub 0/1 ee
card type e1 0 1
card type e1 0 2
controller E1 0/1/0
shutdown
controller E1 0/1/1
shutdown
controller E1 0/1/2
controller E1 0/1/3
card type e1 0 1
