how to find firmware with Cisco Unified CME 8.6(on 2921) and how install?
Hi,how to find the firmware of IP phone 7931g whitch Compatible with Cisco Unified CME 8.6, on router 2921
and how to install it ?
thanks for your reply!  I can not download this use my CCO temporary ,and I see the "dir" command  on my device display as :
Directory of flash0:/
    1  -rw-    74856492  Dec 21 2011 10:11:56 +08:00  c2900-universalk9-mz.SPA.151-4.M3.bin
    2  -rw-        2903  Jan 14 2012 15:31:48 +08:00  cpconfig-29xx.cfg
    4  -rw-        1038  Jan 14 2012 15:31:48 +08:00  home.shtml
    5  -rw-      115712  Jan 14 2012 15:31:48 +08:00  home.tar
    3  -rw-     2999808  Jan 14 2012 15:31:52 +08:00  cpexpress.tar
    6  -rw-     1697952  Dec 21 2011 10:21:00 +08:00  securedesktop-ios-3.1.1.45-k9.pkg
    7  -rw-      415956  Dec 21 2011 10:21:12 +08:00  sslclient-win-1.1.4.176.pkg
261464064 bytes total (181358592 bytes free)------not enough spance for your suggest zip file that more than 200+MB
and I found the CME version is 8.6 with CCP2.6,but which file is above? cpexpress.tar? it cantain phone firmware?
I just want to konw if I should download the phone firmware and update it to my device?
Hall of Fame Super Gold
Re: how to find firmware with Cisco Unified CME 8.6(on 2921) and
To download Cisco software (including phone firmware), you need to buy a support contract.
Yes, you need to purchase the required support contract for gaining download access to softwares published on CCO.
About, your other queries..
1. and I found the CME version is 8.6 with CCP2.6,but which file is above? cpexpress.tar? it cantain phone firmware?
Ans : No, cpexpress.tar does not contain firmwares. It contains files needed for enabling Cisco Configuration Professional. Cisco Configuration Professional is a GUI based device management tool for Cisco access routers. It simplifies router, firewall, IPS, VPN, unified communications, WAN, LAN and basic wireless configuration through easy-to-use wizards. http://www.cisco.com/en/US/prod/collateral/routers/ps9422/data_sheet_c78_462210.html
2. I just want to konw if I should download the phone firmware and update it to my device?
Ans : Yes, you would need it.
You will have to procure additional flash memory if present one is not sufficient.
GP.
799
