07-12-2016 07:22 AM - edited 03-17-2019 07:31 AM
07-12-2016 08:02 AM
from LAB
admin:show network cluster
1X.1XX.182.16X CUCM-10-5-SUB Subscriber callmanager DBSub authenticated using TCP since Thu Jun 30 19:16:33 2016
1X.1XX.1XX.1XX CUCM-10-5.jitender.bhandariabcdefg.cisco.com CUCM-10-5 Publisher callmanager DBPub authenticated
Server Table (processnode) Entries
10.197.182.162
10.197.182.163
admin:
admin:run sql select * from processnode
pkid name mac systemnode description isactive nodeid tknodeusage ipv6name fklbmhubgroup tkprocessnoderole tkssomode
00000000-1111-0000-0000-000000000000 EnterpriseWideData t t 1 1 NULL 1 0
4a2c0a2e-cc9d-4367-aa28-193614e62395 1X.XXX.1XX.1XX f t 2 0 NULL 1 0
b2ee8e33-4632-da2c-3bc4-11987a22d112 1X.XX7.1XX.1XX f t 3 1 NULL 1 0
Lower Node ID would be PUB if you cluster have never been rebuild.
JB
07-12-2016 08:17 AM
You can also run utils service list from CLI of publisher.
at the end of output , if u get Primary Node = True [it is Publisher]
For subscribers, it would be False.
regds,
aman
07-12-2016 07:34 AM
Hi Syed,
from cli you can find that in multiple way. from GUI if you have not backed the server you would see warnings message like below on PUB only and warnings regarding licensing.
WARNING: It has been XX day(s) without a successful backup. Please verify backup configuration.
JB
07-12-2016 07:47 AM
Thank you Jitender.
Could you reference a few commands, please?
07-12-2016 08:02 AM
from LAB
10.197.182.162
10.197.182.163
admin:
JB
07-12-2016 08:13 AM
Once again thank you JB..
07-12-2016 08:22 AM
Happy to help
JB
07-12-2016 08:17 AM
regds,
aman
07-12-2016 08:22 AM
Good one Aman +5
JB
02-14-2018 12:25 PM - edited 02-14-2018 12:26 PM
Even though this is solved, I'd like to add that in the CUCM web GUI, you can go to System -> Server. Then do a find with the search dialog box empty. This will show all of your clusters. When you click on one, it will show "Database Replication"followed by either Subscriber or Publisher.
02-14-2018 07:15 PM
you can also come to know through CTI ID under System ---Call Manager server. for Publisher , CTI ID is 1 while for other servers in cluster , it is the order in which they are installed.
regds,
aman
02-15-2018 09:11 PM
thanks for sharing info.
regds,
aman
