Community Member
How to find the installed CUCM iso is restricted or unrestricted?
How to find the installed software in CUCM9.1(iso) is restricted or unrestricted??
If you don't see the word "unrestricted" after the version on CCMAdmin  or OS Admin page when you login you're running the restricted version  which is the "normal" version with all security features available to be  enabled.
Manish
Community Member
Hi Manish,
Thanks.
Is there any snapshot or sample for the unrestricted iso
(once we login through CCMAdmin or OS Admin page for UNRST)
DP
I'll check in the lab and send it to you.
manish
Community Member
Is there a way to check the installed OVA Template file name??.
DP
Purple
Re: How to find the installed CUCM iso is restricted or unrestri
what u can do is u can login into OS administration through Putty . u get the details of VMWare .
Same can be compared and checked with OVA templates in README  file
http://www.cisco.com/web/software/283088407/97505/cucm_9.1_vmv8_v1.7.ova.README1.txt
CUCM 7500 user node:
     Cisco Unified Communications Manager (CUCM) configuration that
     supports up to 7500 users per node.
     Details:
     Red Hat Enterprise Linux 5 (32-bit)
     CPU: 2 vCPU with 3600 MHz reservation
     Memory: 6 GB with 6 GB reservation
     Disk: 1 - 110 GB disk with pre-aligned disk partitions
you can see UNRST in attached snapshot.
regds,
aman
I think both of us clicked post at the same time [+5].
Manish
Don't think there is a way to find that once it is deployed, you can only check the output of show hardware to get an idea of how many processors, CPU speed , amount of RAM etc were used, like the output below
HW Platform       : VMware Virtual Machine
Processors        : 2
Type              : Intel(R) Xeon(R) CPU           X5650  @ 2.67GHz
CPU Speed         : 2670
Memory            : 4096 MBytes
Object ID         : 1.3.6.1.4.1.9.1.1348
OS Version        : UCOS 5.0.0.0-2.i386
Then you can corelate this with the vm specs on OVA readme.
Manish
Community Member
Thanks amanso and Manish....
DP
1095
