Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
How to Forward inbound (external) calls to another extension
Dear all
I'm facing the following problem with callmanager 6, ew have an operator that stops working at 18.00 and she needs to forward all incoming call, external and internal, to another extension. The problem is that only internal calls are redirected the external simply do not work, they're still ringind on the operator's phone.
Kind regards
Re: How to Forward inbound (external) calls to another extension
What exactly is your scenario? Is the receptionist using Attendant Console? What is your call flow?
I'm using a hunt list which handles all incoming calls to the operators dn. She is not using the attendant console but i do have a pilot point number with call queue.
On your hunt pilot what do you have set on your
Forward Hunt No Answer, Forward hunt busy, and Maximum hunt timer? I would tweak these settings to your preferences. Maybe change the Hunt timer to 4 rings then go to your external DN on hunt no answer?
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/5_0_1/ccmcfg/b03htpil.html#wp1023973
use TOD for that, if you already know at what time she goes home configure the schedules according to that.
Time-of-Day Routing
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/5_1_3/ccmsys/a03tod.html
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Maybe it is the way of doing, but it's quite strange the call forward not working, perhaps this feature do not apply for what i pretende.
i will follow your sugestion, the use of tod, and see the results.
One last question it is possible to program holidays?
Tankx
Sergio
the way to make this work would be to create a translation rule or a CTI RP with the same DN as the pilot point with CFA and use TOD so that when the girl goes home what you reach is not the pilot point.
you can create a TP and hard-code what you want to send to unity as the calling or called # and create a routing rule so they reach a general MB or the MB of a specific subscriber
yes, it's possible to config holidays, there is an option to configure just a particular day and not something that will repeat each week.
javalenc
java
191
