How to get Licence MAC to MCS server?
Best regards.
To download L-CM-DL, I need the "License MAC"
To find address I did the following step:
1. Log in to the Cisco UCM command line interface (CLI) and enter show status.
But in this devices the "show status" comando not exist.
The MCS have 3 Mac address, 2 Giga ethernet and 1 Service-Engine interface,
Which I can use to download the license or which command can I use to see the License MAC.
Thank for help me.
  • IP Telephony
1 ACCEPTED SOLUTION
Red
Re: How to get Licence MAC to MCS server?
On your particular version (6.1.2), you use command "show network eth0 detail" to get the MAC address:
admin:show network eth0 detail
Ethernet 0
DHCP         : disabled           Status     : up
IP Address   : 10.88.7.221        IP Mask    : 255.255.255.000
Link Detected: yes                Mode       : Auto disabled, Full, 1000 Mbits/s
Duplicate IP : no
Queue Length : 1000               MTU        : 1500
MAC Address  : 00:0c:29:8a:7e:49
RX stats:
  bytes   :   3219412021   packets :     15179215   errors :           43
  dropped :            0   overrun :            0   mcast  :            0
TX stats:
  bytes   :   1267274831   packets :      9269296   errors :            0
  dropped :            0   carrier :            0   colsns :            0
Michael
http://htluo.blogspot.com
Super Bronze
It sounds like you are looking at a Cisco ISR or other router - not an MCS server.
Can you do a 'show version' on this device?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Yes, the output of show version command is:
Cisco IOS Software, 3800 Software (C3825-ADVIPSERVICESK9-M), Version 12.4(9)T7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jan-08 18:20 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T10, RELEASE SOFTWARE (fc1)
RO-GPA-01 uptime is 7 weeks, 5 days, 19 hours, 12 minutes
System restarted at 20:06:54 UTC Fri Jan 15 2010
System image file is "flash:c3825-advipservicesk9-mz.124-9.T7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3825 (revision 1.2) with 484352K/39936K bytes of memory.
Processor board ID FTX1236A0YP
2 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
28 Voice FXO interfaces
4 Voice FXS interfaces
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
125440K bytes of ATA System CompactFlash (Read/Write)
Super Bronze
OK - so when you are registering CallManager DLUs, you register these to your publisher MAC address. The publisher (and all other MCS servers) is a HP or IBM based server.
What you have is a router, which can be used as a telephony system if you configure CallManager Express on it.
You can't install DLUs on a router; and you don't need them.
Do you have an actual MCS server and CallManager software?
Aaron
Hi Aaron.
I have a MCS server 7828-I3
But the output of show status command is:
admin:show status
Host Name    : CM7828
Date         : Thu May 27, 2010 13:28:52
Time Zone    : America/Guayaquil
Locale       : en_US.UTF-8
Product Ver  : 6.1.2.1000-13
Platform Ver : 2.0.0.1-1
Uptime:
13:28:53  up 9 days, 18:04,  1 user,  load average: 0.22, 0.40, 0.47
CPU Idle:  89.90%  System:  01.01%    User:  02.02%
  IOWAIT:  05.56%     IRQ:  00.00%    Soft:  01.52%   Intr/sec: 440.40
Memory Total:        6156852K
        Free:          28744K
        Used:        6128108K
      Cached:        3084140K
      Shared:              0K
     Buffers:         127584K
                        Total            Free            Used
Disk/active         43264144K       36138388K        6686220K (16%)
Disk/inactive       43264176K       41033656K          32828K (1%)
Disk/logging       150538756K      122603092K       20288728K (15%)
admin:
I have not publisher MAC Addrees.
Which command I can use to get the MAC
Thanks.
Jose
Red
Ethernet 0
Duplicate IP : no
RX stats:
TX stats:
Michael
1453
